Best Alternator?
Old Aug 3, 2024 | 12:31 PM
  #61
diesel_dan's Avatar
diesel_dan
My mind isn't what it used to be, but I thought some years back someone found a Denso alternator that would work on our trucks...? I've never had one of those fail in the many cars/trucks I've owned that had them. Anyone recall this or should I just chalk it up to fading memory...?
On Edit: Nevermind! It was the 200A alternator off the 6.4s (and maybe later) which are PCM controlled and Won't work on our 6.0s...
Old Aug 3, 2024 | 12:46 PM
  #62
bismic's Avatar
bismic
This 140A unit, and a couple other smaller ones, are on the densoproducts.com web site when entering the 6.0L information in their search engine.
https://www.densoproducts.com/denso-...red-alternator
Old Aug 3, 2024 | 12:55 PM
  #63
Fuzzpuss's Avatar
Fuzzpuss
Originally Posted by wpg_250
400 amps or not, it will sell because it looks so bad azz. They would sell more if they offered that case with the lower amp models at lower prices.
Old Aug 3, 2024 | 01:23 PM
  #64
wpg_250's Avatar
wpg_250
Curious if it's normal to see battery volts bounce around, like say between 13.75-13.93 when at speeds? I guess it's those HIGH output units that keep battery volts at a steady 14-14.2 yeah or is bouncing around rather normal for all alternators? Just never thought of it till now.
Old Aug 3, 2024 | 01:35 PM
  #65
diesel_dan's Avatar
diesel_dan
My voltages bounce around like that - I can see highs in the low 14s and particularly when the engine bay is hot, lows in the 13s, but yeah it's constantly changing. Mine is the factory original, optional High Output 140A with an overdrive pulley on it...
Old Aug 3, 2024 | 01:38 PM
  #66
wpg_250's Avatar
wpg_250
Ok cool, thanks brudda 🙂
BuckHammer
34
Dec 24, 2024 02:16 PM
olfordsnstone
Oct 18, 2022 05:45 PM
Skier041
Apr 5, 2008 11:11 AM
Mil1ion
Electrical Systems/Wiring
Jan 25, 2002 12:44 PM
