Alternator recommendation
Old Oct 18, 2022 | 02:02 PM
olfordsnstone's Avatar
olfordsnstone
Hey all, I replaced my alternator over 10 years ago with a Ford Remanufactured alternator. I don't use my truck that often, mostly for towing. Anyway, it seems that it has given up the ghost as my batteries have suddenly died and they are only between 3 and 4 years old. I will be taking the bats to Auto Zone to have them load tested, but I suspect the alternator is the issue. My question is, does anyone have a recommendation for a replacement alternator? Is a Ford remanufactured alternator the way to go or is there a more reliable alternator out there to buy. I don't think Ford offers "new" alternators... or do they? In short, please steer me the right way on my next likely purchase.
Old Oct 18, 2022 | 02:08 PM
Antonm's Avatar
Antonm
Check FICMrepair.com (link to alternator page below), they have a pretty good reputation for 6.0 alternators.
https://www.ficmrepair.com/index.cfm...=cat/cat81.htm
Old Oct 18, 2022 | 02:48 PM
diesel_dan's Avatar
diesel_dan
Hey there Tim, long time no post!
Here's a recent thread with some good info in it, bottom line was go with a 140A NEW unit unless you have large electrical draws - the thread tells you which ones and where to buy: Take care!
https://www.ford-trucks.com/forums/1...lternator.html
Old Oct 18, 2022 | 02:59 PM
Coronado's Avatar
Coronado
I have a DC Power "stock replacement" alternator which at the time was 170 amp output (i believe). It was the highest output I could get without upgrading my charging system wiring. It's served me very well since 2014. I think 180 amp is the lowest output DC power alternator you can get now.
Old Oct 18, 2022 | 05:05 PM
olfordsnstone
Originally Posted by Antonm
Check FICMrepair.com (link below alternator page below), they have a pretty good reputation for 6.0 alternators.
Thanks, I hadn't thought of ficmrepair. Last I read they had a good reputation.
Old Oct 18, 2022 | 05:45 PM
TooManyToys.'s Avatar
TooManyToys.
Three to four years for some battery situations is not abnormal, with infrequent use and no maintenance charging. Declaring an alternator the issue when no mention of a battery light (charging light) may be premature before going into the wallet lions den.
The battery light tells you the alternator is not charging.
1973supercamper
Mar 24, 2016 07:28 AM
Skier041
Apr 5, 2008 11:11 AM
BigTomMiller
Aerostar
Sep 26, 2003 07:37 AM
z 97ford1
1997 - 2003 F150
Aug 24, 2003 07:53 AM
