Sponsored by: Auxito
Calling power window gurus
Old Nov 8, 2024 | 07:07 PM
  #31
Rob_in_NWA's Avatar
Rob_in_NWA
3rd Gear
sorry for the late reply -
trouble shooting steps a little out of order but yes move the boot from dash side and looked no breaks we could see, same on moving the boot from the door side
Fuse is good too
checked power on the switch test light lights up
then pulled the connector from the motor in the door and plugged into the new motor on the regulator, no power on the new motor ...
I have a Haynes Repair Manual and a buddy is helping but we are stumped on what to do next
thanks
Rob
Old Nov 9, 2024 | 02:31 AM
  #32
manicmechanic007's Avatar
manicmechanic007
You were to see if the original motor worked by manually giving it power and ground
You need test leads or jumper wires to do that, even a test light will run a window up and down
Power the alligator clip end of a test light and while checking for ground at the switch the motor might move
That would mean the motor and reg are okay and you have a switch or wiring issue
Sounds like that is what you have
Now get a EVTM and do the master switch diagnosis (master switch is the drivers door switch)
You can sometimes figure out what's happening by examining the power and ground feeds to the other windows
That master switch takes the power and ground and switches them to each satellite motor
Old Nov 9, 2024 | 01:02 PM
  #33
Rob_in_NWA's Avatar
Rob_in_NWA
3rd Gear
Thanks my buddy and I will get on that at the end of the week coming when we work together
Huntington
Sep 30, 2020 02:09 PM
2.7EcoBoost
2015 - 2020 F150
Aug 5, 2019 11:12 AM
RockyMtnRanger
Mar 6, 2008 07:22 PM
Taboo
Jul 24, 2007 12:24 PM
sgt
Nov 1, 2005 01:09 PM
