Relays and Diodes
Old Jun 26, 2024 | 10:19 AM
John11.25's Avatar
John11.25
Relays and Diodes
1996 F 250 PS. I recently had a no start issue, WTS light would not come on. According to the flow chart I checked the fuses, which were good. I finally swapped some relays in the power distribution box and the truck started.
I would like to keep spare fuses and relays to avoid being stranded somewhere in the future, and I can source those items online.
There is a PCM Diode in the box that appears to be in the same circuit. I would like to keep a spare one but according to Ford it is obsolete, and I can’t find one anywhere.
It is a diode, so it can’t be complicated. Has anyone replaced this part, and what did you use?
Thanks.
Old Jun 27, 2024 | 03:23 PM
John11.25's Avatar
John11.25
Thread bump.
I know turbos and h pops are more popular, but I am sure there are some folks that are electronics knowledgeable out there.
Have you had to replace the PCM diode in the power distribution box, and if so what did you use? The part number on mine is
F2TF 14A604 AA. (Obsolete). According to the manual it has something to do with the power train control system relay coil.
Maybe it’s not something that fails, or it’s not critical?
Thanks again.
Old Jun 27, 2024 | 04:08 PM
96XLTczny's Avatar
96XLTczny
Found one for later model Mustangs on fleabay, item # 194412866050.
Suppose it's to prevent backfeeding a relay circuit. A 1n4001 diode might work?
If you look at that fleabay you see the diode has a notch in it for polarity.
Old Jun 27, 2024 | 09:09 PM
John11.25's Avatar
John11.25
Thanks, I’ll check it out.
Old Jul 1, 2024 | 10:42 AM
knottyrope's Avatar
knottyrope
Amazon Amazon
not a bad price
Old Jul 1, 2024 | 11:23 AM
John11.25's Avatar
John11.25
Thanks for the reply. The part number is different. Mine is more of a maxi size with the blades at 90 degrees to each other.
I have seen a picture of that Amazon part number on a different site and it looks different than mine.
Old Jul 1, 2024 | 02:46 PM
96XLTczny's Avatar
96XLTczny
Now that we know it is larger, it could be a higher amp diode like a 1N5401, which is 100V 3A. !N5402 is 200V, and so on up to 1000V.
Old Jul 1, 2024 | 05:01 PM
Hit Man X's Avatar
Hit Man X
What is issue with identification of old/bad diode and just swapping it? Just count the rings and colors.
Think of it like a hose bib, only allows flow one way.
Old Jul 1, 2024 | 05:56 PM
John11.25's Avatar
John11.25
This is the part in question.
Old Jul 1, 2024 | 06:59 PM
96XLTczny's Avatar
96XLTczny
10 pack of 1N5401 diodes are $5.50 on Amazon. Bend the leads to match spacing, cut leads just long enough, crimp & solder 2 spades to the wire leads at right angles oriented with stripe to left like the diode on that part. Pot it in epoxy if you like. Done.
For decades color codes were used on capacitors, inductors and are still used on some resistors. Most everything today is SMT, surface mount technology.
Some of the older germanium diodes did have color coding. Not so much the silicon diodes.
As an SWL electronics hobbyist, I learned to read color codes in the sixties as a teenager.
Old Jul 1, 2024 | 07:05 PM
Hit Man X's Avatar
Hit Man X
This guy gets it.
Order from Mouser or Digikey. I prefer Mouser as local to me in Mansfield, TX .. despite my ex oldlady working there still.
Old Jul 1, 2024 | 07:22 PM
96SD's Avatar
96SD
Just make sure you know which side is cathode and which is anode when doing the soldering.
*edit*My bad looks like he explained the orientation in his post.
Old Jul 1, 2024 | 09:38 PM
John11.25's Avatar
John11.25
Thank you, this is helpful information.
rd65
Oct 19, 2021 01:10 AM
bristolstud2002
1997 - 2003 F150
Jun 3, 2021 06:21 AM
Rusty_S
Electrical Systems/Wiring
Mar 27, 2016 01:23 AM
Rusty_S
Garage & Workshop
13
Feb 3, 2016 08:54 AM
FordTruckfan89
Feb 16, 2015 12:35 PM
