Help! With fuel.
Old Jul 1, 2024 | 10:48 AM
Warren1126's Avatar
Warren1126
1st Gear
Help! With fuel.
Morning! Ford has been in the family for decades and this problem has us wondering! Foe some reason the truck is not getting fuel? We have changed the fuel pump, the dual tank switch, fuel bowl reservoir, starts for a little while and then it stops getting fuel.
Old Jul 2, 2024 | 08:05 PM
Harveyearlolstad's Avatar
Harveyearlolstad
I would confirm fuel shoots at the shraeder valve while running and cranking, then start working your way down and disconnect fuel line blowing them out at both ends using an air compressor. Then blow the selector valve at only 5 psi from motor side with valve on both rear and front tanks but with the lines disconnected, pull the lines going to the tanks and blow them, finally I would drop the tanks (or remove the bed) and pull the sending units to confirm the shower heads are intact and no debris is in the tank. That will also tell you the condition of the inside of you tank.
rmdonaghy
May 24, 2024 09:05 PM
V8SHO
Nov 29, 2020 10:27 AM
kupiec20
Jan 25, 2018 05:15 AM
Semper Fordelis
Jan 18, 2011 10:20 AM
stevegooch
May 30, 2004 05:27 PM
