1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2002 F350 7.3 ESOF woes..
Old 05-24-2024, 01:16 PM
FlyingWrenches's Avatar
FlyingWrenches
FlyingWrenches is offline
6th Gear
UPDATE: Fixed, it was a combination of the PVH Solenoid, GEM module, and the transfer case motor. By swapping in all the original ones I was able to determine that all three of these infact need to function for ESOF to work, back in business baby!
Good afternoon gentlemen.
I have a '02 F350 CCLWB SRW 7.3 4x4 Lariat.
She's got 345,000 on her and I went with my father to buy it in '03. It towed a camper around the southe east when we used to race Motocross, and then after drove the family and dad to work till 2020 when I purchased it.
The truck is equipped with the oh so amazing ESOF on the dash with Auto hubs. I never had functional 4x4 via the switch. So I've just recently started to diagnose and try to fix this.
​​​​​​I have access to AllData as well as a Autel Scan tool for when I reference anything.
I couldn't communicate with the factory GEM (4x4) module under the dash behind the glove compartment, the windshield previously leaked and I had to replace it so I'm assuming this is what caused the issue.
I found one with a matching part number on eBay and replaced the old one. Now, I can communicate with the module and read codes, + after the truck starts up, for a brief moment the 4x4 low and 4x4 high lights illuminate, that previously did not occur.
I found two codes in the module section on my scan tool, and referred to AllData for further information.
DTC P1834
DTC P1876
I followed the instructions and found my "PVH" as AllData calls it or "4WD Actuator Solenoid" as AutoZone called it to be faulty. I was able to confirm the harness between the module and the PVH was good, as it Ohm'd out perfect with no resistance. However the solenoid itself did not OHM out at all and displayed an Open loop. I hated the new one and it was between 0.09 and 0.04, and installed it. This has fixed my two codes, DTC P1834 &DTC P1876.
However still now, with the engine on and in neutral, foot on brake I still cannot get the transfer case to switch with the ESOF (4x4 switch) on the dash. I did command the dash lights and both high and low 4x4 illuminates fine.
The truck now only throws ,
In the Overhead Trip Module
B2148 PWM(Pulse-with modulation status) Input Circuit Failure.
P0500 VSS (Vehicle speed sensor) Circuit fault
This overhead console hasn't worked for 10 years. Clearing them makes the stay away for quite a while.
In the HEC (Hybrid Electric Cluster) module
C1284 Oil pressure switch failure
B1352 ignition key in circuit fault
and again,
B1352 ignition key in circuit fault.
I however have no CEL on at anytime, truck starts and stops fine etc.
What's the deal? What else can I diagnose from this point?
Thanks.
The following users liked this post:
Old 05-24-2024, 01:31 PM
redford's Avatar
redford
redford is offline
Received 1,632 Likes on 956 Posts
If you turn the front locking hubs from AUTOMATIC to LOCK, does your 4x4 system work?
Old 05-24-2024, 01:44 PM
FlyingWrenches
6th Gear
No change, besides locking the hubs to the axle shafts.
Transfer case still in 2WD, switch does not acuate the transfer case, driveshaft still spins freely
Old 05-24-2024, 02:11 PM
redford's Avatar
redford
redford is offline
The most common cause of this is the shift motor failure.
Old 05-24-2024, 02:25 PM
FlyingWrenches
6th Gear
I'm about to parts slap a new one on as soon as I get back home lol. Parts shotgun is firing on full auto today lol
Old 05-24-2024, 02:42 PM
redford's Avatar
redford
redford is offline
OK. Load the parts cannon and let us know how it goes.
Old 05-24-2024, 06:29 PM
FlyingWrenches
6th Gear
That did it, I swapped in all the old parts after to confirm and all three failed at some point, PVH, GEM, and Transfer Case Motor lol.
Thankfully though this wasn't a wiring issue.
Old 05-25-2024, 01:26 PM
redford's Avatar
redford
redford is offline
Sheesh, a three-fer
Old 05-25-2024, 01:28 PM
FlyingWrenches
6th Gear
Sheesh, a three-fer
I lied. It worked fine all day yesterday, this morning went to test it again, KOEO, it tried too, then failed. Now it's not working again, with a new code, Code P1865 Transmission Transfer Case Contact Plate Power Short To Ground.
Got another new TCase motor, gonna parts slap it and see if maybe this cheap Dorman one failed.
Old 05-25-2024, 05:29 PM
FlyingWrenches
6th Gear
New TCase motor and it's back up and running, found water in a connector and reassembled with dielectric grease this time on the new unit
gspvtjoker9
1997-2006 Expedition & Navigator
12-31-2021 01:44 PM
larkimg
06-27-2012 09:32 PM
1998f150stx
1997 - 2003 F150
04-17-2010 07:42 PM
jwt5004
1997 - 2003 F150
04-15-2005 01:48 PM
Quick Reply: 2002 F350 7.3 ESOF woes..
