03 F-350 no 4wd action at all, bad module? Should dash lights go on with key?
So I buy this 03 F-350 with shift on the fly 4WD knowing nothing happens when I turn the 4WD switch. I found the transfer case motor was bad (open), replaced that but still nothing. I measured voltage to the control module at the connector pins and those seems to be ok. Tested selection switch and that seems to be ok. I grounded pins at module to light the 4x4 and Low Range dash lights and they work ok. I tested the transfer case control relays and also was able to click them grounding the module connector pins. I didn't try that test with the new transfer case motor plugged in yet. I didn't want to mess anything up or get it stuck in neutral somehow.
About all that is left is bad control module?
The manual says the two 4x4/Low Range dash lights should come on with the key on as a bulb test? Can anyone confirm that? Mine don't so I assume that points even more to the module?
I just want to make as sure as possible before I drop $300.
Anyone have a good recommendation of where to buy that module?
Thanks,
Larry
Thanks,
Larry
Here is what the manual says:
4WD system indicator lights
The 4WD system indicator lights illuminate only under the following
conditions. If these lights illuminate when driving in 2WD, contact your
Ford dealer as soon as possible.
4x4 - momentarily illuminates
after the engine is started.
Illuminates when 4H (4x4 High)
or 4L (4x4 Low) is engaged.
LOW RANGE – momentarily
illuminates when the ignition is
turned to the ON position.
Illuminates when 4L (4x4 Low) is
engaged.
TooManyProjects
1999 to 2016 Super Duty
12-21-2018 11:13 AM
JayromeD
1997-2006 Expedition & Navigator
02-17-2018 12:34 PM
underdogl3
02-18-2016 07:00 PM
neemeth
11-13-2014 07:17 AM
