Power steering filter?
Old May 22, 2024 | 04:25 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I had no idea where I stole it from, feels like that was 10+ years ago
Old May 22, 2024 | 09:42 PM
wpg_250's Avatar
wpg_250
Anyone put on of these filters on their trans fluid line?
Old May 22, 2024 | 10:50 PM
bismic's Avatar
bismic
If you feel that you need better transmission fluid filtering, install the 2008 transmission pan and the filter that comes with it.
Old May 22, 2024 | 10:58 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Originally Posted by bismic
For nostalgia - here is one of the first posts on it (IIRC initially recommended by Beachbumcook - from 2009):
https://www.ford-trucks.com/forums/8...ing-flush.html
Was just about to tag him...
Old May 22, 2024 | 11:40 PM
wpg_250's Avatar
wpg_250
I'll have to check the pan and see if the truck has that upgrade already.
Old May 23, 2024 | 05:24 AM
Hartwig's Avatar
Hartwig
I read from power steering fluid? Thought PS fluid = ATF??
I'm using ATF Dexron 3 in the system, same as in the transfer gearbox .
Old May 23, 2024 | 06:32 AM
bismic's Avatar
bismic
Ford recommends MerconV/Dexron III.
I use Mobil 1 synthetic Mercon V.
Old May 23, 2024 | 07:18 AM
wpg_250's Avatar
wpg_250
Yeah it's ATF, but when it's in the steering system I refer to it as steering fluid lol. I use the Valvoline max life stuff.
Old May 23, 2024 | 10:17 AM
Antonm23's Avatar
Antonm23
Originally Posted by wpg_250
Have you ever opened one up to see if it's actually doing anything?
No, haven't opened , or even replaced, one yet, hence the reason for the statement "I suppose they work" in the original post. Probably should replace one as it has been in service for at least 30K miles now. Guess I'll order up a replacement for it, swap them out and cut the old one open to see what (if anything) it caught.
But even if nothing is inside the filter when its opened, does that mean it wasn't working, or does that mean my power steering fluid system was clean enough to start with?
Mcrafty1
Feb 24, 2020 06:52 PM
firedog4689
Jan 6, 2011 01:25 PM
DKW 86
Sep 1, 2010 10:32 PM
yeha4x4
Dec 6, 2005 11:04 AM
thesaintoc
Dec 13, 2003 10:44 AM
