Sponsored by: Real Truck
power steering whining
Old Jan 6, 2011 | 10:21 AM
firedog4689's Avatar
firedog4689
I have a 2000 f250 sd 4x4 with 280k on it. The power steering has always has a whine to it but lately it has gotten worse. I was told that changing the fluid to a quality synthetic could help. Any ideas would be great. I don't have a lot of cash so......
Old Jan 6, 2011 | 10:38 AM
gearloose1's Avatar
gearloose1
Start with tossing a filter on it and see if the cleaned and flushed fluid will do it.
If not... pump..
Old Jan 6, 2011 | 10:44 AM
firedog4689
Sorry to be stupid but how do I filter the fluid and what kind of filter?
Old Jan 6, 2011 | 10:45 AM
gearloose1's Avatar
gearloose1
Do you have hydroboost?
There is a TSB out for attaching a filter.
Old Jan 6, 2011 | 11:04 AM
firedog4689
sorry again man, I don't know what a hydoboost is or a tsb. Your starting to think you should have kept your mouth shut, this idiot is a pain!
Old Jan 6, 2011 | 11:11 AM
gearloose1's Avatar
gearloose1
Tsb 07-11-10 Brake Pedal Kickback Or Grabbing
FORD:
1997-2007 E-Series
1999-2008 F-Super Duty
2000-2005 Excursion
This article supersedes TSB 99-25-8 to update the vehicle model years. ISSUE:
Some 1999-2008 F-Super Duty, 2000-2005 Excursion, and 1997-2007 E-Series vehicles equipped with Hyrdo-Boost® brake booster system may exhibit a brake pedal kickback and/or grabbing condition when applying the brakes. This may be caused by contamination within the power steering system.
ACTION:
Filter the power steering fluid by installing a temporary filter in the power steering system. Refer to the Service Procedure below.
SERVICE PROCEDURE
1. Verify that the line from the pump and the line to the gear at the Hydro-Boost® are in their correct orientation (and not crossed). The passenger side goes to the pump, the driver side goes to the gear.
2. Attach a pinch-off clamp to the lower power steering hose approximately 6" (15 cm) from the lower port of the power steering cooler to keep fluid from emptying out of the system when the hose is disconnected.
3. Disconnect the power steering hose from the lower port on the cooler. Cap the cooler port to minimize fluid leakage and immediately install the temporary filter in line with the power steering hose using hose clamps to retain the filter (the filter needs to go in the low pressure line that goes from gear to cooler to reservoir, where it would be most accessible).
4. Attach the other end of the filter to the cooler using the clamps provided.
5. Remove the pinch-off clamp from the power steering hose.
FILTERING PROCEDURE
CAUTION: BE SURE THAT THE PARKING BRAKE IS APPLIED DURING THE FOLLOWING STEPS 1-7.
1. Check power steering fluid level before starting the vehicle.
2. Start the vehicle and allow it to idle for approximately 15 seconds.
NOTE: DO NOT HOLD THE STEERING AT LOCK FOR MORE THAN 5 SECONDS.
3. Turn steering wheel lock-to-lock 10 times.
4. Pump service brake pedal hard to floor 25 times.
5. Turn steering wheel lock-to-lock 5 times.
6. Remove the filter and reconnect the power steering line to the cooler. Discard the filter. Fill the power steering system. Refer to Workshop Manual (WSM), Section 211-00 Power Steering System Filling.
7. With the engine at idle, gradually apply the brake pedal until fully applied. If the brake pedal kickback persists, replace the Hydro-Boost® brake booster. Refer to WSM, Section 206-07.
PART NUMBER PART NAME
XC3Z-7B155-BA Power Steering Fluid Filter Asy
5C7Z-2005-B Hydro-Boost® Asy - 1999-2004 F-Super Duty / 2000-2005 Excursion
6C3Z-2005-AA Hydro-Boost® Asy - 2005-2007 F-Super Duty
7C3Z-2005-AA Hydro-Boost® Asy - 2008 F-Super Duty
F7UZ-2005-AA Hydro-Boost® Asy - 1997-1998 E-Series
XC2Z-2005-AA Hydro-Boost® Asy - 1999-2001 E-Series
6C2Z-2005-AB Hydro-Boost® Asy - 2002-2007 E-Seres
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
MT071110 Use SLTS Operations If Available; Claim Additional Diagnosis Or Labor Performed As Actual Time Actual Time
DEALER CODING
BASIC PART NO. CONDITION CODE
2005 07
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2007 Ford Motor Company
See if this applies.
Old Jan 6, 2011 | 11:24 AM
firedog4689
I don't know you but thank you, I have alway found that this forum is full of people who care about fords, and more importantly, care about other ford owners. Thanks again!
Old Jan 6, 2011 | 01:25 PM
redford's Avatar
redford
FTE Leadership Emeritus
If you have a diesel engine, you have hydroboost.
john hardy
Jan 8, 2022 02:44 PM
jim collins
Oct 29, 2016 09:36 PM
Cjohnson80
Jun 16, 2016 08:27 AM
rickdavis81
17
Mar 29, 2014 07:40 AM
5.4L to Freedom
Dec 16, 2010 05:51 PM
