Power steering filter?
I'm running a smaller pulley wheel for increased fluid flow fwiw so I figure that and a top shelf filter and I should be good to go, but again not sold on it yet.
Thanks
https://www.ford-trucks.com/forums/1...ne-filter.html
https://www.ford-trucks.com/g/album/800039
I'll post more on installing one a bit later.
https://www.genosgarage.com/product/...-steering-pump
Filtran 3/8 filter:
https://www.transmissionpartsdistrib...ower-steering/
Unfortunately, the OP removed the pictures:
https://www.fordtruckfanatics.com/th...-install.3516/
The line you need to install the filter in is the rubber line that goes from the power steering assist unit on the fire wall to the plastic oil reservoir on the drivers side of the pick-up. Also, you install it so that the direction of flow is from the power steering assist unit to the reservoir.
https://www.superdutypsd.com/power_steering_flush.php
https://www.amazon.com/dp/B0787KWZPS
Filtran 3/8 filter:
Yeah pretty straight forward, doubt I can screw it up lol. So the Magnafine is better than the Raybestos used in your pics?
My steering fluid/atf is still pretty new, but I'll be swapping out my used 2016 6.7 steering box for a brand new 2020 6.7 box here soon and figure it would be a great time to remove and clean the res and do a good flush as well. Lot's of good info, thank you
When it comes to the filters, I have no idea which is better (or if they are any different internally). I have always liked Magnefine products, so that would be my preference. No other reason.
https://www.ford-trucks.com/forums/8...ing-flush.html
https://www.dieselsite.com/dieselsit...ingfilter.aspx
Have you ever opened one up to see if it's actually doing anything?
