Windows won’t roll down, motor has power
I bought my 6.0 ex about a year ago and have been chipping away at things here and there and I’ve finally got to the windows.
I bought it knowing they were stuck in the up position which is fine since I rarely drive it but I’d like to get it fixed before summer.
Anyways, when I press the down button from the drivers control on all 4 windows nothing goes down. If I press down on any of the other doors window buttons individually . Nothing goes down. I can’t imagine all 4 have bad motors so I’m hoping it’s something simple.
When I press the up/down button I do hear something engaging towards the front of the truck. Sounds like a whirring noise coming from the engine.
I don’t even know where to start so thanks in advance for any tips.
Thanks!
so I know it’s getting power and so are all the others. When I hit the down button the windows move ever so slightly.
I find it weird that all 4 of the window motors or whatever went bad. Is that common?
anything else to check?
I had the rear driver operate up but not down, unhooked it spun fine with direct power, switches all checked good, it was a poor ground for that one.
But yes the motors could be wearing out, all at once would be a bit odd, put possible. You can use a meter and a 9 volt battery (just because it is small and has enough power to operate the motor) to check the motors.
I got a new regulator and motor for the drivers side yesterday, I’m gonna replace it today or tomorrow and I’ll check back in.
I was just going to get the motor and leave the regulator but I figured for an extra $30 or whatever I might as well be safe than sorry especially since everything IS 20+ years old.
My main question was if there was some central power source that sends extra voltage to all the windows, I figured since all 4 weren’t working properly maybe there was a common motor or something that was weak and not sending enough juice to them and I could start there. That doesn’t seem to be the case (I don’t think) so I’m gonna give the replacement motor/regulator a shot
I oiled the heck out of the window and channels as well and that didn’t really do anything. All I had on hand was 3in1 oil. I’m gonna clean the tracks and get silicone spray tomorrow after work and give that a shot.
I removed the rubber weather stripping from the inner side of the window and no change. The only other thing I can think of is that either a) the track is somehow bent which seems unlikely b) something isn’t providing enough power to that motor or c) the rubber part in the track on the inner door and the exterior weather striping is maybe gummed up?
Any other suggestions on what I should look at?
If I remember the wiring correctly (can look it up in the tech folder here if I remember correctly) the power for all the windows goes through the driver door switch first, then to the other doors.
These vehicles are getting older and wiring can be a real p.i.t.a. sometimes. Took me a week to find the parasitic draw on my 2001 Ex.
Give it a good look over for any of the tracking to be bent, or rusty at pivot points. As I believe you said above you needed to do that still. The bearing on the scissor tracks in other vehicles I have seen rusty giving the issue you are having.
After the once over... Best I can say is grab a decent volt meter, and crack a beer, and be thorough when you check for voltage and grounding ohms. Check the switches and the motors directly and the resistance for the wire in between. If the wiring all comes out good then I would look to sticking issues caused by the rails, weatherstripping, etc.
I have a few older vehicles and those have not come up as a reason for window issues yet. And the F250 I have is still the stock stuff (whats left of it) that it rolled of the assembly floor with about 40 years ago.
So I also noticed a weird noise from the engine compartment when I was pressing the up/down window button so I taped the button to window up and tracked it. The window switch is somehow activating the washer fluid pump which was empty. I filled the reservoir and now when I press window up or down, the rear wipers spray water. I don’t know what the hell is going on now.
Another fun thing is that I also learned that When I press the power seat buttons they also activate the wiper pump.
when I disconnect the pump, I get no power to the windows or the seats.
This is making me insane, I’m probably just gonna sell this thing as is rather then spend days or thousands for a shop to go thru and fix all the hack wiring the previous owner did.
So frustrating but any ideas that dont require me to re wire this whole truck?
Can get water intrusion from the windshield that can drip on the fuse box causing it to corrode on the backside that faces upwards (opposite side of fuses). This can cause all sorts of electrical issues. Almost sounds like that is a serious contender for your issue.
Someone has a nice write up on how to clean it up, It wasn't that bad to do, just took a couple hours to take apart clean up and put back in. I did it when I was searching for the parasitic draw that kept killing my battery.
Addressing the water leak would be next after getting things to work properly again. Several posts on how to fix that in this forum too.
