stupid power windows...
Old May 14, 2010 | 07:34 PM
johnboggs21's Avatar
johnboggs21
well both my power windows have crapped out and only half *** work. You can hear the window motor cranking away, but the window will move a little bit sometimes and sometimes wont move at all. Its annoying as hell especially since the a/c dont work. Anybody know how hard it is to convert to hand crank windows?
Old May 14, 2010 | 09:11 PM
oreocreaming's Avatar
oreocreaming
easy, just get new doors lol.... you can get the complete door for less then work and effort then it would take to convert them.
Old May 14, 2010 | 10:00 PM
johnboggs21
I was kinda hoping to keep my doors lol. My truck is enough colors as it is without throwing 2 more into the mix lmao.
Old May 14, 2010 | 10:13 PM
IDIDieselJohn's Avatar
IDIDieselJohn
And people still ask me why I hate power options!
Old May 14, 2010 | 10:35 PM
93_F250's Avatar
93_F250
I had a similar type of problem - We have the same year truck so perhaps my solution will work for you.
https://www.ford-trucks.com/forums/showpost.php?p=8844149&postcount=17
Old May 14, 2010 | 10:36 PM
johnboggs21
aah yea I remember reading that. I just dread tearing those damn doors apart.
Old May 14, 2010 | 10:40 PM
93_F250's Avatar
93_F250
might be less work and $$ then converting to manual windows...
Old May 14, 2010 | 10:41 PM
johnboggs21
I agree, but I find that anything that involves taking the door apart to be a ****ty job.
Old May 14, 2010 | 10:45 PM
IDIDieselJohn
Damn I shouldn't have sent my old doors to the scraper, they were abit rusty at the buttom, but good enough for you.
Burgundy doors on a blue truck
Old May 14, 2010 | 10:49 PM
johnboggs21
great like I need 1 more color in the mix lol. So far Ive managed to keep it blue, just different shades lol.
Old May 14, 2010 | 10:52 PM
IDIDieselJohn
Mix and match
Old May 14, 2010 | 11:20 PM
Sycostang67's Avatar
Sycostang67
I had to do the gear plugs on my passenger motor, it wasn't too bad. At least it's only $8 instead of $50 or more for a new motor.
Old May 14, 2010 | 11:35 PM
LCAM-01XA's Avatar
LCAM-01XA
I take my door panels off about once a month or two, it's no big deal at all. To be able to remove the window motors you nee to drill 1/2" holes in the locations marked with small dimples in the sheetmetal, heck if I know why Ford didn't have them pre-cut considering how many other holes there are in them doors from the factory. You'll also have to grind a slot to get to the third bolt, on fullsize passenger cars you drill a hole for it too but the trucks just need a slot starting off at one existing cutout in the door. The bolts for the window motors take 8mm or 5/16" socket, then to pull the motors out the doors you want to have the speakers out first. Then you take the motor gears boxes apart like showed in that link, and from here you have two options - one is to buy new dowels, and the other option is to pull the dowels out and install regular 1/4" hex nuts in their place, you stack two per dowel location so 6 nuts per motor. I've done this more times that I care to remember, it's fairly easy really.
Old May 16, 2010 | 07:24 PM
johnboggs21
I did exactly what ya said and both windows work perfect now. Man stacking those nuts in there and slipping that gear down in there, talk about aggravation at its finest lmao.
I have to ask, why do you tear into your doors so much>?
Old May 17, 2010 | 01:59 AM
LCAM-01XA's Avatar
LCAM-01XA
Cause I can't leave well enough alone - whether it's installing speakers, swapping mirrors, lubing the linkages, or simply screwing down a cheap cup holder... No particular recurring reason, just random mods here and there.
