Parking brake light
Old Apr 14, 2024 | 03:09 PM
kd5zll's Avatar
kd5zll
Parking brake light
I removed and cleaned my parking brake switch, and the blade connector for it, with brake cleaner. Got all the residue off. Still no light on the dash. I know, on the scale of things, its silly/trivial, but id like it to work. All the other dash lights work, so i dont "think" its the bulb. Any ideas where this failure might be?
Old Apr 14, 2024 | 04:10 PM
uglypitbull's Avatar
uglypitbull
I have had a few trucks with only one bulb burnt out.
Old Apr 14, 2024 | 04:14 PM
kd5zll's Avatar
kd5zll
For the record, it was working, intermittently, got better after i blindly sprayed some pb blaster on the switch, and then it stopped, and i havent seen it on in over a year
Old Apr 14, 2024 | 04:19 PM
uglypitbull
Have you pulled the dash to test for juice? Might be the place to start at least.
Old Apr 14, 2024 | 07:24 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Check continuity across the switch first. That is where you've been monkeying around so check there.
Old Apr 14, 2024 | 07:43 PM
Tpayne621's Avatar
Tpayne621
You can simply put a jumper to ground on the wire at the switch to see if it's switch or wiring side. It's a single wire. When it's ground it should turn the light on in cluster.
Old Apr 14, 2024 | 07:59 PM
kd5zll's Avatar
kd5zll
This right here is why i have a love hate relationship with this forum. I love that other minds weigh in, and remind me of the simple things, keeping me from chasing my tail. I hate when that same advice leads to me feeling like a walking ID-10-T error code....
You called it. Wasnt connecting across that stupid washer. Filed the connecting face, and the light works now.
That stupid piece of plastic with a spring and blade connector costs 30$ to replace.
Thank you.
alod3794
Aug 31, 2020 09:40 AM
78 f150 400
Mar 19, 2018 03:00 PM
Ex-Jermin
Oct 28, 2016 01:08 PM
BFTUFF
1997 - 2003 F150
Jul 5, 2012 09:34 PM
battleriver
Jul 23, 2006 02:29 PM
