.3 micron CCV filter
Old Jun 10, 2024 | 08:44 PM
  #136
Overkill2's Avatar
Overkill2
Originally Posted by speakerfritz
we are talking about two different things…let me clarify
a. Moving the S&s return filter to the basis. This would give me room for the ccv filter in the engine bay. I don’t think there is a temp cost penalty since the return filter routes hot fuel. Any concerns for static freezing of the fuel in the filter would not be any different from static freezing in the engine bay.
b. The racor ccv filter. Overkill pointed out that racor recommends keeping the filter case warm or hot. I think this means when you shut the engine down…a warm or hot filter case would let the goop run down to the drain better. The racor discussion is suggesting that if the case of the filter quickly cools…goop accumulates on the inside walls of the filter housing. I don’t know why this goop wouldn’t slide down to the drain during the next engine run but Racor is so concerned about it that they sell a filter heater. So my thought was if I put the filter in the engine bay at the firewall …it would stay hotter longer than if I frame mounted it.
now…I still don’t know if I am going to return the ccv to the intake or keep it free air. Engine seems to run better with the free air model.
so right now…if I return to intake I plan to use the racor filter element. If I leave it free air I’m going to replace the favor filter with a roll of perforated sheet metal with 1mm holes.
i don’t think I care about racors filter case concerns if I don’t use their filter.
as a side note…I have noticed linear back pressure with the s&S return filter meaning the lift pump pressure seems to climb which I think is due to the s&s return filter backing up. Which is probally why s&s went to a higher micron return filter and spe created their sensor solution…having said that…I plan to use a multi port manifold for the return filter and put a sensor on it. My long term vision is to put a large 2 micron return filter with a multiport manifold and have a sensor as well as having my lift pump return terminate on the manifold. I am also thinking about adding a return path using a filler neck hose with a fitting and moving the manifold close to there with everything that needs a return line having their own return line to the manifold instead of the current arrangement in which s&s , the lift pump people, etc, wants to t fitting the existing return line at the engine bay .
just some random thoughts and I hope it answers your question.
https://ssdiesel.com/new-product-pre...p4-bypass-kit/
It states in there that Parker Racor couldn't keep up with S&S's demand for their filters.
Old Jun 10, 2024 | 09:08 PM
  #137
speakerfritz's Avatar
speakerfritz
I have a few on the shelf and have not trouble ordering them.
But…I’m thinking of moving to a larger capacity filter.
Old Jun 10, 2024 | 09:13 PM
  #138
Overkill2's Avatar
Overkill2
Yeah I have the white Marine 2 micron versions with the drain. S&S had Parker make them the 2 micron with no drain in the black housing as Parker does not offer them in their catalog.
Old Jun 10, 2024 | 09:18 PM
  #139
speakerfritz
Drain is pointless on the pressure side of a pump.
you will only get water in a water filter if the filter is on the suction side.
Old Jun 10, 2024 | 11:36 PM
  #140
kayakingpoodle's Avatar
kayakingpoodle
So do you have a 2011 thru 2016
or 2017 and later
different filter architecture's
2018, but I fail to see the relevance as all of my filters are CAT high or ultra high efficiency filters, nothing from Ford in regards to fuel filtration on my truck, with the exception of the S&S Donaldson simply because it is a great filter, and there is no reason other than it would match my other filters brand wise, though I am excited to hear if there is relevance.
Old Jun 10, 2024 | 11:37 PM
  #141
kayakingpoodle
If that were true would there be any warranty claims denied due to rust in the system?
Old Jun 11, 2024 | 03:57 AM
  #142
speakerfritz
Let me know if you ever get water in a water filter on the pressure side.
Old Jun 11, 2024 | 08:23 AM
  #143
kayakingpoodle
I already have 2 water separators in my system, so chances are small for water to make it past them but Murphy is a known a-hole. So I am not going to put one on that side, Not sure anyone makes a filter I can afford that will hold that much pressure any way, but if you think water never gets to the injectors you're living in a fantasy world.
Old Jun 11, 2024 | 11:08 AM
  #144
rufushusky's Avatar
rufushusky
I believe the fuel cooler uses the same 1/2" quick connect fittings as the HPFP fuel return lines, so you could reuse those fittings if you wanted to move the return filter down to the frame.
Old Jun 11, 2024 | 06:43 PM
  #145
Overkill2's Avatar
Overkill2
Right, but the only way you can get spares is by buying what they offer in the 2 micron version... these are marine filters. Kind of sucks that Parker couldn't keep up with demand, but I like the SNAPP filters and have no problem using those marine 2 microns...
Old Jun 15, 2024 | 10:41 AM
  #146
Overkill2's Avatar
Overkill2
SBE products
So Fritz, I'm thinking of going in a new direction...
I've been looking at SBE's external catch can and especially their CCV recirculating box...
I sent them an email asking if the external catch can is two way flow, in and out as it has a second threaded port on the top with a allen head plug on it, but all I got was to consider their CCV box and that they don't recommend using other systems parts, Mishi's adapters for the valve cover, with their can. Plus I do not think that Chance's wife really knew what I meant... To satisfy my own curiousity, I will call and talk to someone to see if the can be used as flow in and back out can like my Mishimoto oil catch can.
But I do really like their CCV box because the design looks solid and functional, and made to take apart and clean... while I like the Mishi catch can, it's a PITA to drain a lot in the winter and it's smaller than the SBE can. If I went with the larger SBE can, if it's even an option, I'd still have to get under the truck to drain in the winter. While both are not cheap, I'm leaning towards the CCV box... by itself and no Mishi catch can anymore.
Old Jun 15, 2024 | 01:05 PM
  #147
speakerfritz
the only thing I don’t like about the spe box is that it returns fluids back to the sump….so condensed unburnt fuel vapors roll back into your oil pan….this is what I am trying to get away from as that is exactly what the stock setup does.
I need 100% of what is evacuated out of the ccv not to go back into my sump.
big fuel dilution problem with us metro drivers
Old Jun 15, 2024 | 02:00 PM
  #148
Overkill2's Avatar
Overkill2
I'm not against using their big can if it can be used in the same capacity as the Mishimoto catch can application with their adapters. But I notice how the Racor filter does have a return hose also. I also think the Mishi can does not stop all oil as well...
But yes, you are in a league by yourself with the Rotten Apple metro driving for sure. I don't have that problem fortunately as mine gets hot, climbs hills, completes regens and limited stop and go but not big city traffic jam stop and go...
I may start a thread to ask if anyone is running a SBE big catch can and if that's a port on top... they do list it as universal in their description of it...
Old Jun 15, 2024 | 02:13 PM
  #149
speakerfritz
I definitely will not be running the Racor drain back into sump.
Old Jun 15, 2024 | 02:44 PM
  #150
jimzpsd's Avatar
jimzpsd
And this is the reason the majority that do the reroute just dump them to the ground, it is really that simple.
