Engine Load
Old Mar 30, 2024 | 03:18 PM
  #76
jcb804's Avatar
jcb804
Was it 2008 or 2009 that the 3V 4.6L was an option? If you've got the 3V you have a bit more engine than the famous 2V. Not that more engine makes up for not having a 3/4 ton but its a minor plus.
Old Mar 30, 2024 | 10:42 PM
  #77
Dave1972's Avatar
Dave1972
2008 is the two valve. Three valve didn’t come out until 2009.
Old Mar 31, 2024 | 11:42 AM
  #78
jcb804's Avatar
jcb804
2V is a great engine. Many of our sub contractors (plumbers, electricians, drywall) have the 2V in their vans that tow a tool trailer loaded out not as much as you're towing but probably pretty close. 400-500 thousand miles on a lot of those vans.
Old Apr 1, 2024 | 03:06 PM
  #79
redford's Avatar
redford
FTE Leadership Emeritus
I thought the F-150 got a 3V 4.6L and 5.4L in 2004? The F-250/350 got the 3V 5.4L and 3V 6.8L in 2005?
Old Apr 1, 2024 | 03:28 PM
  #80
Dave1972's Avatar
Dave1972
My Pickup: 2008 Ford F150 1/2 ton P/U 2WD (8 Cylinders W 4.6L FI SOHC 281 CID) VIN 1FTRX12W18KC88251
The eighth digit of the VIN can indicate the number of valves. If it's a W, it's a two-valve engine, and if it's an 8, it's a three-valve engine.
So...mine is a 2 valve.
Old Apr 1, 2024 | 03:36 PM
  #81
Dave1972's Avatar
Dave1972
FYI: I've just about figured out what's wrong with my refrigerator. I'm waiting on the part. If my replacement part fixes it, I'll let everyone know how I figured it out.
Basically, for my issue (lights on, fan on, not cooling), it's either the compressor board or the compressor. If the three pins of the compressor show very little resistance on a multimeter (like a couple of ohms), then the compressor is good, and it's the compressor board (as long as 12v is going into the compressor board). If there was no light and no fan, and it wasn't cooling, and 12v was going into the circuit board, the circuit board would be bad.
Old Apr 1, 2024 | 04:52 PM
  #82
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
You are correct:
An axle code 19 on a Ford F150 is interchangeable with other axles that have the same gear ratio. The number 19 indicates a 3.55 ratio, and this code is also known as L9.
Here are some other axle codes for Ford F150s:
15: 3.15 ratio, also known as L5
27: 3.31 ratio, also known as L3
26: 3.73 ratio, also known as B6
H9: 3.55 ratio, also known as L9
You can find a car's gear ratio by decoding its VIN. The VIN is often located on the driver's side of the dashboard, where the dashboard meets the windshield, or on a sticker inside the driver's side door.
I tell you one thing…this park is a gem! I highly recommend it. Sewer and water hookup at each site…right off the Mississippi River.
Starlink works GREAT!
What you have is a 120V AC compressor and the board you are talking about is a small inverter converting 12 volts DC to AC for the compressor.
Denny
Old Apr 1, 2024 | 05:40 PM
  #83
6.8L_V8_DRW's Avatar
6.8L_V8_DRW
Denny
Everchill has the 12v-24V DC Danfloss style direct current compressors. It is definitely not 120V AC.
Old Apr 1, 2024 | 05:56 PM
  #84
rvpuller's Avatar
rvpuller
Yes the compressor runs on DC only but that big box on the side is a dedicated inverter for the compressor.
Denny
Old Apr 1, 2024 | 06:08 PM
  #85
6.8L_V8_DRW
Denny
The RVs use cheap knock offs and that is not how the 3 Everchills I worked on are. The compressor board is separate and does not put out 120V.
Here is a common RV compressor.
https://www.ebay.com/itm/155734674929
Old Apr 1, 2024 | 06:50 PM
  #86
rvpuller's Avatar
rvpuller
https://www.youtube.com/watch?v=sO-x1sqDZ20
I took a closer look (haven't looked in a long time) and they have gone to a permanent magnet motor that are not 120V but instead a inverter driven motor that's really not a DC motor or a 120V but variable frequency motor similar to the inverter compressors used in the high efficiency variable speed a/c units.
We have a residential frig the draws 56W off the same inverter that runs our entertainment center and our chest freezer. A lot simpler and cheaper.
Denny
Old Apr 2, 2024 | 11:12 AM
  #87
6.8L_V8_DRW
Denny
That is not simple nor cheaper.
Jolly Roger Joe
52
Mar 8, 2015 06:56 PM
Blue_Oval1
All Things Towing
Jul 22, 2014 09:12 PM
Steeley11
2009 - 2014 F150
17
Nov 6, 2013 07:59 PM
auto385
2009 - 2014 F150
Dec 6, 2011 01:38 PM
Built_Ford_Tough_757
All Things Towing
Sep 27, 2010 08:52 AM
