Need a trailer to haul my truck cross country
Some of you have trailers for enabling old Ford trucks to follow you home. I am not only envious, but curious as well. I have only ever pulled a 2-horse trailer and a 12 foot rocket trailer, so the car trailer concept is new to me.
Since I don't ever plan to drive my '51 F4 across this beautiful country, I will need an open trailer that will haul her. I'd like to also have my Harley on this trailer with Betsy, either in front or back crosswise on the trailer if possible (preferably in front). But that would mean the trailer would have to be over 20" long (loading deck).
Betsy is 18' 6" (222") long and the rear track is about 7' 1" (85") wide with the duallies. I believe the track with the outside duallies removed is under 6' (67"). I really don't want to remove the outside duallies to load the trailer, but I have found only one trailer manufacturer so far with 102" (8.5') width and 22' length. That's a Load Trail. And I think I'll need a special permit to pull a trailer that's 8.5' wide.
Betsy weighs about 5,000 pounds and the bike is just under 700 pounds. So the trailer load weight rating has to be over 6,000 pounds. I'm just guessing that the GCWR would need to be around 8,000 pounds.
I'll of course want twin axles and trailer brakes (probably required). And wouldn't I want the front wheels over the axles since that's where most of the truck weight is?
I remember someone here built his own hauler, but don't remember who it is.
What do you guys have, and what do you suggest?
Received 4,132 Likes
on
What are you going to tow this with, Joe? To be honest, I bet it would be cheaper to just ship it ahead to wherever you want to go, compared to buying a truck big enough to tow it across the mountains safely, a trailer, etc.. You could ride the Harley to meet it. Or buy an F-1 for trips....
I think I'll figure a way to pull the bike on my utility trailer behind my Ranger.
But that still leaves Betsy to be trailered.
on
Lets brainstorm this a bit.
Consider hauling the Harley in the bed of the tow truck. An eighteen foot deck trailer would then work.
The standard trailer axle is rated at 3500 lbs. IMO, this is not enough payload, IMO. With a trailer chassis weighing in at 2000 lbs, itself, that leaves little payload. My trailer has an eighteen foot deck and two 5000 lb axles.
How about an overdrive transmission for Betsy? Probably the cheapest.
on
I'd hate to get it up there (or back down)! You'd need 20 ft ramps at least.
I think the utility trailer (very low) is the best bet for the bike.
I'd be towing it with the rented one-way moving truck.
And my next project will probably be a '65 F100 instead of an F1.
Heck, we don't even have a place to go yet. But I'm getting out of this Liberal madhouse, and taking my guns and ammo with me.
