Newbie 460 issue...HELP!
Old Mar 15, 2024 | 09:59 AM
  #46
440 sixpack's Avatar
440 sixpack
The engine has been bored so it's safe to assume the crank has been ground. the bearings will tell, and if it's been ground then looking at the surfaces of the bearings it's not that bad. I've seen far far worse ones still holding decent oil pressure.
If I'm misreading the OP's budget and expectations for this engine correct me.
Old Mar 15, 2024 | 10:08 AM
  #47
52 Merc's Avatar
52 Merc
My concern is with the observed lack of wear on the cylinder walls and the extent of the damage to the bearings and crank, it looks like an engine that either wasn't rebuilt correctly before, or wasn't cared for after, or both. It may run by slapping it together on the cheap again, but it won't last as long as the previous rebuild. As I said before, the junk that tore it up is still inside the engine, and it will tear it up again in short order without a proper cleaning and rebuild. If none of this matters, that's fine, op's been given advice, can make an informed decision and knows what he's getting into. My 2c.
Old Mar 15, 2024 | 11:06 AM
  #48
dbear75's Avatar
dbear75
A lot of great feedback, and I appreciate everyone's input. My plan is get it hot tanked and inspected thoroughly. If the engine shop thinks it can be put back together with various new parts, then that is what I will do. If it does need more of a complete rebuild, then their cost will dictate what I will do. I have already had the np435 and np205 gone through and sealed back up. Since those are freshly done, I would hate to put this motor back in with it and not be a good runner. Cost is a factor, but right now I do not know what that is exactly. Hope to get with the engine shop on Monday, and I will let you guys know what happens. Thank you again for all the help so far!
Old Mar 15, 2024 | 11:12 AM
  #49
52 Merc's Avatar
52 Merc
When you take your parts to the machinist, be sure to take the bearings with you, show them to the guy and make sure he understands the concerns.
Old Mar 15, 2024 | 12:48 PM
  #50
440 sixpack
If the machinist is competent he'll tell you to grind the crank. probably hone the cylinders and hard to say on the heads. this is where the difference between a real build and good enough comes into play. hopefully he'll give you realistic options not just the optimum ones.
Once you go down the optimum path you need the rods reconditioned, align honed, decked, balanced...it goes on and on. there's no point in doing it half right so be ready for anything.
Old Mar 15, 2024 | 03:46 PM
  #51
dbear75's Avatar
dbear75
LOL...that is what I am afraid of...but hopefully it proves to be in decent shape. Thank you sir.
4x4 Redneck
27
Jul 29, 2013 08:24 PM
frazier23
Oct 19, 2011 07:45 PM
sibbles
Nov 9, 2007 06:48 PM
trannysmoker
Mar 28, 2004 08:43 AM
nbaff
Sep 17, 2003 10:49 PM
