Throttle Body issue
Old Feb 9, 2024 | 05:59 AM
Kcooper96's Avatar
Kcooper96
Trailering
Throttle Body issue
Hello!
I have a Manual 4 spd/overdrive 1988 f150 with the 302 5.0 engine, I recently cleaned the throttle body, changed the egr valve, IAC valve, TPS sensor, and air filter in order to fix idle problems. I now have a sticking gas pedal that causes it to run wide open every time I hit the gas. went to order new throttle body from Rock Auto and they're out of stock. I could only find BBK performance throttle bodies online, and holy crap are they expensive! also, they have what looks like an extra vacuum port in between the two throttle ports on the body that mine doesn't have. will those throttle bodies work in the event I can't find the exact one I need? or is there a way I can fix mine? any tips appreciated.
Old Feb 9, 2024 | 06:34 AM
R&RFord's Avatar
R&RFord
https://www.ebay.com/itm/186270205118
Old Feb 9, 2024 | 06:53 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I don’t understand how the throttle is now “sticking wide open” after you cleaned it. Did you break the return springs when you cleaned the throttle body? With the engine off, disconnect the cable and then manually open the throttle. Does it snap closed or is it staying wherever you left it?
Are you sure the TPS is oriented correctly? It is possible to have the tabs on the throttle body and sensor wrong which will send the wrong (open throttle) voltage to the computer.
Why did you replace those parts in the first place? The BBK part has three vacuum ports because it is generic replacement for all years. It comes with vacuum caps to block off the unused port(s) for your application. IMO, they are junk. If yours is actually broken, I would find a used OEM part.
Old Feb 9, 2024 | 07:06 AM
Kcooper96's Avatar
Kcooper96
Trailering
Are you sure the TPS is oriented correctly? It is possible to have the tabs on the throttle body and sensor wrong which will send the wrong (open throttle) voltage to the computer. Why did you replace those parts in the first place?
i don't understand either. I don't think I broke the return spring, what I did do (which may have been a mistake) was remove the throttle plates to clean them. The plates might have been seated improperly, but I don't know how they could be cause they only seat one way.
Old Feb 9, 2024 | 07:08 AM
My4Fordtrucks
I edited my last post to answer another question.
Oh. I would not have removed the butterflies. That was completely unnecessary. My guess is that you released tension on the springs.
Kcooper96's Avatar
Kcooper96
Trailering
Originally Posted by R&RFord
This is not the correct one. There is o port on this one too that my current throttle body does not have
Old Feb 9, 2024 | 07:16 AM
rla2005's Avatar
rla2005
The extra ports are for the EVAP system. Some model years/engines use one port, others two ports. Then you have the early EFI with no ports. Perfectly fine to cap those off if not needed in your application.
Old Feb 9, 2024 | 07:30 AM
Ethanfoster's Avatar
Ethanfoster
If the BBK throttle body has an extra hole for air that your truck doesn't use, you might have to close it up if your engine doesn't need it. But you have to be careful doing this to make sure air doesn't leak where it shouldn't.
Old Feb 9, 2024 | 07:31 AM
Kcooper96's Avatar
Kcooper96
Trailering
Thank you! I did not know if I could cap that or if it needed to be hooked up to something. Rock auto has one for manual trans and another that does not specify. Thank you again!
Old Feb 9, 2024 | 07:58 AM
Kcooper96's Avatar
Kcooper96
Trailering
this is the one that is currently on my engine. right above the red tag there is an added port on all the other throttle bodies, just wanted to clarify that we are talking about the same port.
Old Feb 9, 2024 | 08:00 AM
Kcooper96's Avatar
Kcooper96
Trailering
NVM, I guess it is the correct one lol
Old Feb 9, 2024 | 08:49 AM
Conanski's Avatar
Conanski
OK so they are now misaligned slightly, that is fixable just loosen the screws slightly and exercise the throttle so that it opens and closes freely, then snug up the screws. You are probably best to remove the TB to do this.
Old Feb 10, 2024 | 06:29 AM
manicmechanic007's Avatar
manicmechanic007
I would get a good used throttle body from the junkyard
In the future, clean the plate every 30k miles
Only clean one using carb foam with the engine running
Never soak one or remove the staked in throttle plate screws
Old Feb 10, 2024 | 12:04 PM
My4Fordtrucks
I use throttle body cleaner because it is supposed to be safe for coated throttle bodies.
Mountain_anderson
Oct 27, 2023 12:25 PM
Zsawyr
13
Nov 16, 2022 04:50 PM
sail2244
1983 - 2012 Ranger & B-Series
Mar 6, 2010 07:03 PM
98FordTruck
1997 - 2003 F150
Feb 14, 2008 03:11 AM
Flash351
Dec 31, 2005 03:54 PM
