throttle body position problems
Old Oct 26, 2023 | 11:48 AM
Mountain_anderson's Avatar
Mountain_anderson
Hi all,
Currently tracking down why my 1986 F150 has a rough idle. I checked the throttle position sensor and its normal voltage is 5.03, the signal without throttle is 0.94 but when given full throttle it rests at around 3.89 volts. Should full throttle not be 5.03 or am I wrong and its functioning correctly?
Old Oct 26, 2023 | 01:12 PM
Max Capacity's Avatar
Max Capacity
I'll assume you have 302EFI engine. This may help...
https://www.google.com/search?q=thro...t=gws-wiz-serp
Old Oct 26, 2023 | 01:39 PM
Max Capacity
This link may be more help with voltages.
Also see related threads below, the one from Chuckles,,, see post #4
Old Oct 26, 2023 | 01:43 PM
Max Capacity
In one of the related links below, I saw in post #4 it should be 5.0v at full throttle.
You may have broken parts inside yours.
Old Oct 26, 2023 | 01:58 PM
Mountain_anderson
Yes 302 Efi
Old Oct 26, 2023 | 01:59 PM
Mountain_anderson
Inside the tps? Could it possibly be something wrong with the throttle body by chance and is there a way i could diagnose it? I just would like to know before I puchase a new one
Old Oct 26, 2023 | 02:05 PM
Max Capacity
The first youtube video, the 20 minute one, shows the inside of his was broken, its just plastic in there.
Look through those links. I'm not the expert, I just did some searching. I doubt the TB is the issue, unless its filthy.
Old Oct 26, 2023 | 02:07 PM
Max Capacity
This one, about 18 minutes through, he just removed the sensor and saw the broken plastic.
Old Oct 26, 2023 | 02:37 PM
Franklin2's Avatar
Franklin2
Take the throttle linkage cables off and then move it by hand while checking the voltage. Also make sure to look inside at the butterfies and make sure they are not all coked up with black greasy soot.
Old Oct 26, 2023 | 02:38 PM
Franklin2's Avatar
Franklin2
For your rough idle problem, I would first check the codes from the computer.
Old Oct 27, 2023 | 12:25 PM
diggerrigger's Avatar
diggerrigger
Take the throttle linkage cables off and then move it by hand while checking the voltage..
This^. With the throttle cable hooked up, are the throttle plates even opening all the way? In many cases with these EFI equipped trucks they are not.
Susyqt45
Apr 6, 2023 05:56 PM
EPDP99
Nov 13, 2022 03:10 PM
john-9
Aug 1, 2021 10:49 AM
gdoggy
1983 - 2012 Ranger & B-Series
Jun 19, 2003 09:48 PM
chuckles738
Feb 3, 2003 03:11 PM
