Speedometer
Old Nov 13, 2023 | 02:51 PM
DieselDog409's Avatar
DieselDog409
Speedometer
On my 50 f5 can i use a 51-52 speedometer so i dont have to use a seperate glass cover for it as i am making a custom cluster.
Will the speedometer cable thread into it and read accurate?
Old Nov 13, 2023 | 04:08 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Cable thread will work but as for accuracy, that is determined by the gear in the trans. So the question is , is it accurate now. That is something you will have work out once everything is together and running. Tire size and rear axle ratio determines the gears in the transmission to establish accuracy.
Old Nov 14, 2023 | 04:04 AM
Badmoonreizen's Avatar
Badmoonreizen
Once you have done all of the above, download a speed app to your phone, and test the accuracy.
Regards, Mark
Old Nov 14, 2023 | 08:11 AM
DieselDog409
it was accurate when i blew the old engine and parked it. So it should still be accurate now with the new motor.
This is good to know about the threads, thanks.
Old Nov 14, 2023 | 08:12 AM
DieselDog409
Also i dont have a phone i post with my school chromebook.
JoelStobbe
Sep 28, 2022 06:47 AM
robinsoneb
Dec 12, 2018 08:35 AM
midsouth
Nov 4, 2011 07:57 PM
semperfiob
Apr 28, 2007 11:53 PM
46yblock
1947 and Older Ford Trucks
Jan 7, 2004 12:34 AM
