Clicking speedometer
Old Nov 4, 2011 | 02:09 AM
midsouth's Avatar
midsouth
My speedometer clicks as I'm driving. I understand the cable needs to be greased? Is this a diy or do I need to have a professional do it? Any pictures would help.
Old Nov 4, 2011 | 03:06 PM
Franklin2's Avatar
Franklin2
Pull the cluster out. Once the speedo cable is disconnected from the cluster, you can reach in with needle nose and pull the cable completely out of the center. I would then wipe it down with wd40 and re-install it. I would also put a little wd40 on the back of the speedo where the cable connects to try and lube the bushing in the back of the speedo.
Old Nov 4, 2011 | 03:29 PM
midsouth's Avatar
midsouth
What do you mean by the cluster? The whole dash, or disconnect it from underneath?
Old Nov 4, 2011 | 06:25 PM
Franklin2's Avatar
Franklin2
The dash piece that has the speedo and the gauges.
Old Nov 4, 2011 | 07:57 PM
ctubutis's Avatar
ctubutis
I use white lithium grease for speedometer cables.
ScottyC50
Oct 7, 2018 10:54 AM
BlueOx460
Aug 4, 2016 05:07 PM
fordtreexr
Oct 5, 2015 03:41 PM
Conanski
Dec 1, 2010 01:26 PM
