No boost when engine is hot
Old Jun 9, 2023 | 09:51 AM
  #31
Maxium4x4's Avatar
Maxium4x4
No fuel No Go, plus it kills injectors. Upper fuel filter housing has a metric port to tap into and get pressure readings.
Old Jun 9, 2023 | 09:53 AM
  #32
bismic's Avatar
bismic
Originally Posted by Seisyll Black
I finally remembered to check the engine temp at completely cold. This is my readings.
Seems like a fairly significant temperature difference on Intake Air for a completely cold engine. How long had it been since the past time the engine was run? Then again it could just be the day heating up. Hard to tell. Also, your EBP is a bit high. I like to see .5 psi difference or less, yours is 1.2 psi higher.
Like John said though - nail down the fueling.
I had a fuel pump relay that would act up more when hot than when cold.
Old Jun 9, 2023 | 01:23 PM
  #33
Jokester00's Avatar
Jokester00
Post your EBPvoltage as well as pressure. WOuld be nice to correlate the two.
And I agree with the above as well - need to figure out fuel pressure for sure! That's a MUST on these trucks. However, that being said, I would think that the PCM wouldn't command the VGT to 15% just because of low fuel pressure, seeing as it doesn't even MONITOR fuel pressure, right? Or am I going about this wrong?
-jokester
Old Jun 9, 2023 | 05:58 PM
  #34
Seisyll Black's Avatar
Seisyll Black
The engine had no been run since the night before so it should have been dead cold.
I thought I had a gauge but the one I have only reads to 30psi. I would need to buy a new gauge and fittings. I just serviced the fuel filters as well as the air filter (all new) at the bigining of may. Trouble started long before that, but admitedly could still be a failing fuel pump.
Old Jun 9, 2023 | 06:01 PM
  #35
Seisyll Black
-jokester
You are correct, the PCM does not moniter fuel pressure or base oil pressure in psi.
Im using torque pro and do not see a pid for EBP voltage. Im going to check online to see if it can be add manually.
Old Jun 9, 2023 | 09:56 PM
  #36
Seisyll Black
Cleaned, and reinstalled the turbo again and the problem presists. New VGT solenoid will be installed tomorrow, and ill get a pressure gauge and fittings to check the fuel pressure.
Old Jun 10, 2023 | 04:38 PM
  #37
Seisyll Black
PSA - dont mash the fuel filter by 8nstalling wrong. -$70 buecaue I dont trust it now.
Couldnt find a EBP pid for voltage for torque pro
Removed, cleaned, installed tubro, checked all hoses and tubes.
installed the old vgt solenoid to test the engine before installing the new vgt solenoid
While I had the tubro out, I cut the butt conectors out and hard soldered the wires back together. Retaped and installed the wiring.
Currently the truck is running great. Fingers crosed it lasts.
Old Jun 10, 2023 | 04:40 PM
  #38
Seisyll Black
This is the latest readings
Old Jun 10, 2023 | 04:42 PM
  #39
Maxium4x4's Avatar
Maxium4x4
Still need to have a Fuel Pressure reading for the future health of the injection system.
Old Jun 10, 2023 | 05:12 PM
  #40
Seisyll Black
Copy that. It is on the list to do. Ill post it here once its complete.
tjmike
18
Jun 18, 2016 08:44 PM
rat49f6
35
Aug 24, 2009 03:07 PM
bakerbuilttracks
Oct 16, 2008 10:00 PM
John311t
Nov 15, 2006 07:13 AM
cant remember
25
Nov 13, 2006 12:16 PM
