Build a boost leak tester. Get a 3" PVC cap, 7/16ths drill bit, a 1/4" NPT tap, and an air nipple. Drill the cap, tap, and install the air nipple. Might want to put some teflon tape around the air nipple threads (I did). Also, you probably want to scuff up the rim of the PVC cap to give the intake tube something to grab onto. Even at only 25psi that thing will fly with a vengeance if it pops loose. LOL
Egts seem high too
would would any of these be the cause?
I'm going to get a 4" pvc pipe cap and a tire stem and make a leak tester ...what psi should it hold? 30 psi?
If I find no leaks can someone post instructions for the wastegate adjustment
Ok so we all agree leak that's good I like not having an internal debate
So what things should I do to check
1.) Uppipes ... I check both from top and bottom so its not them
2.) Intake and i/c piping... I will build that tester tonight and do that
3.) ???
4.)???
