boost ?
Old Oct 16, 2008 | 09:26 PM
bakerbuilttracks's Avatar
bakerbuilttracks
boost ?
ok dumb question... when driving normal what boost levels should i see? like thking off from stop not going over 2200 to 2500 rpm. or crusing at like 50mph on a flat surface.
Old Oct 16, 2008 | 09:28 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
You should see 10-15psi.
Old Oct 16, 2008 | 09:41 PM
uliman's Avatar
uliman
I've been enjoying my new gauges for a while now and, of course, keep a keen eye out on the boost gauge. I drive like an old woman in order to keep my mpgs up; in town I rarely get up over 2k rpms so my boost is around 5 psi. When merging on the freeway (all of this without load) I get up to 2.5k rpms and the boost hits 10. This weekend I'm putting a load (7,000 lbs) on and will hit the local mountain to see what the boost will be.
I was worried initially about the low boost figures but none of the four upper boots seems to be leaking (will check the spyder boots this weekend). I will also check my up pipes to see if any soot is present indicating leaks. The engine seems very powerful (mind you, the DP is not yet hooked up; got the control switch in and the connecting cord; just have to pull the PCM).
Then I started reading about turbos and boost and it seems that the higher PSIs don't start coming on until you hit WOT and/or do a load; in other words, the turbo boost only comes on when the engine computer senses that it is necessary. One way to test this, is to rev the engine up while in park - even at 3k rpms the boost is still very minimal because there is no load on the engine.
So low boost may not be symptomatic of any worries.
Old Oct 16, 2008 | 09:44 PM
PowerstrokeJunkie
The turbo works off exhaust velocity, pressure, and temperature. More load on the engine, more heat and pressure built up in the pre-turbo exhaust. Compressor accelerates and stuffs air into the engine, that then goes out of the engine into the exhaust side and spools it more, in a nice cycle. I could get 5 or so psi in neutral.
Old Oct 16, 2008 | 09:47 PM
bigsteve1969's Avatar
bigsteve1969
on a mild throttled run........ crusin i see about 2.5-3 psi..
Old Oct 16, 2008 | 09:50 PM
bakerbuilttracks
yea i see bout 4 to 6 from stop to go and bout 10 arround 25krpm as well just checking but got 2 questions what is WOT stand for. and i got a bd adjustable wastegate actuator what should i expect or notice when i install it
Old Oct 16, 2008 | 09:51 PM
bigsteve1969
WOT = wide open throttle.... (pedal to the floor)
Old Oct 16, 2008 | 09:53 PM
bigsteve1969
not sure on the bd but i'll let some1 that knows more bout that chime in
Old Oct 16, 2008 | 10:00 PM
bakerbuilttracks
ahhh wot i get it haha yea bout the bd id really like to know
