Long time lurker
Old Mar 26, 2023 | 06:51 PM
  #61
Don Ruff's Avatar
Don Ruff
Originally Posted by ESwift
See what Brian says about the tuning.
I would suggest a cncfab stage 2 hpop and the kc300x stage 2 if you arent towing much or at elevation. It seems like you are wanting the extra power potential.
Do you have any transmission upgrades?
6 spd trans with South Bend that is suppose to be good up 400hp.
Old Mar 26, 2023 | 07:22 PM
  #62
ESwift's Avatar
ESwift
CNCFAB
very nice!
Old Mar 27, 2023 | 06:21 AM
  #63
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by Wes444
Surely I'm not the only one that's noticed the trend of being passed by the bowtie or horned goat badged trucks flying by @ 80+ mph on the flat or downhill sections with a 35 to 42ft travel trailer in tow with some bad rear end squat going on, usually with some seesaw action, with the trailer tires bulging, which indicates either improper inflation, too low of load ranged tires, or unlevel or poor weight loading heating up the sidewalls.
Then when it's time for the grades they lose speed forcing me to get into the left lane to pass their dumb buts @ 65mph. So that once we crest the hill they can fly past everyone who maintains the same speed going down as we do going up
Usually when a Ford passes me it's a one time thing cause they don't lose speed on the hills, or they have trailers that look under control and properly taken care of
That and I'm a cheapskate. Get my best mpg @ 62-65
Drop 1 full mpg per 5mph over that.
Just cause we can lay down more POWah with injectors and turbos doesn't mean our brakes magically improved with those speed gains. The new truck's with bigger better brakes and true exhaust brakes make towing faster safer for them than we can pretend to tell ourselves we are. If you've ever towed here in the Ozarks down a long 7 or 8% grade with 13k# on your tail 65mph is about all I feel our brakes could successfully do a panic stop on
I never get passed.
Old Mar 27, 2023 | 08:40 AM
  #64
Wes444's Avatar
Wes444
Whoa pardner, hold up y'all....
You missed in his list a crucial missing piece. No mention of bellowed uppipes...
I hit 32# with stock turbo and injectors way back when
Old Mar 27, 2023 | 11:21 AM
  #65
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I never get passed.
Technically, you didn't get passed, you lost due to a catastrophic failure...
Old Apr 18, 2023 | 10:41 PM
  #66
Don Ruff's Avatar
Don Ruff
Just finished installing
CNC stage 2 HPOP
CNC HPOP lines
KC Turbo stage 1
Uploaded tune revision from Jellibuilt.
Also installed a new IPR. HAHAHA, after no start issue after HPOP/Turbo install.
I am really impressed all around!
Thank you to those who helped me, greatly appreciated!
Old Apr 19, 2023 | 01:36 AM
  #67
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Great news! Thank you for reporting back!
Old Apr 19, 2023 | 06:36 AM
  #68
ESwift's Avatar
ESwift
CNCFAB
CNC stage 2 HPOP
CNC HPOP lines
KC Turbo stage 1
Excellent to hear!
Yit96
Sep 6, 2019 01:43 PM
c mobley
23
Aug 26, 2016 09:20 AM
Hoothooters
36
Oct 20, 2015 01:54 PM
Dybree
Apr 18, 2015 08:26 AM
calllendargirl
Dec 13, 2013 12:42 AM
