2.5 inch stroke
Old Mar 4, 2023 | 04:48 PM
CarterDawson's Avatar
CarterDawson
2.5 inch stroke
I’ve tried this 2 times in a row. Where you put the straw down the spark hole and you measure the stroke. I’ve gotten 2.5 inches in a row. The valve cover says it’s a 360, but the guy that owned it was positive it was a 390. He said it’s a hopped up one. Used to be a mud truck that would do wheelies. It’s sat for about 15 years. But this doesn’t make sense. It seems to be very very high compression. I can hardly roll it over when I get it to 180°.
Old Mar 5, 2023 | 07:52 AM
lee's Avatar
lee
Hi,
First off, please confirm that you can rotate the crank a full 360*.
Concerning the high compression,... remove all spark plugs when rotating to measure the stroke.
Old Mar 5, 2023 | 09:36 AM
GPatrick's Avatar
GPatrick
Which two cylinders are you checking? Compare #1 at TDC to #4 which should be at BDC. 1 and 4 are the front and rear cylinders on the passenger side in case you are used to numbering from a different manufacturer.
Old Mar 5, 2023 | 11:20 AM
cbrown9064's Avatar
cbrown9064
Could be a 352 also...
This is common. 352/360 truck often magically become a 390 when posted for sale...
Old Mar 5, 2023 | 12:08 PM
CarterDawson
Yes. With all plugs pulled it still is impossible to roll over. I’ve come the the conclusion that the cylinder walls are rusted. Im gonna put some mystery oil in it and let it sit for some time. The back right spark plug is seized in its hole. Just soaking it in kroil.
Old Mar 5, 2023 | 02:39 PM
85e150's Avatar
85e150
After 15 years of sitting after being a "gently used" mud truck the engine should be torn down. Otherwise a clacking oil burner is in your future.
Old Mar 6, 2023 | 12:33 AM
CarterDawson
Yes. If I get it to run and if it’s a 390 inch am gonna rebuild it and have it bored out. It was locked up, but I got it freed up. Tomorrow I’m going to measure the stroke again and see if I can’t see if it’s a 360 or 390.
Old Mar 6, 2023 | 01:32 PM
CarterDawson
I went out and measured the stroke now that it’s freed up. Unfortunately it’s a 360.
Old Mar 6, 2023 | 01:47 PM
85e150's Avatar
85e150
Same block as a 390 so don't scrap it......
sklinemansk
Oct 19, 2008 02:27 PM
78fordranger
Apr 19, 2008 06:23 PM
DanGinTC
33
Mar 19, 2005 05:53 AM
75explorerxlt
Aug 18, 2002 12:29 AM
dynamic
Jun 19, 2002 11:34 PM
