If he's going to go at it with a saw which he already said wasn't much room, he'd probably be better off using a dremel with a right angle attachment with a cutoff wheel..
Yea, I appreciate your thought on this one and have thought about going after it with a dremel, but that dang fuel tank....
Hey everyone on the thread here, my apologies, I have not been getting notifications on replies to this thread, so I'm playing catchup. I'll check my notifications to see if something has come un-toggled.
I think I may try the nut splitter first, if that doesn't work, I'll block it off with a piece of wood and just rough it off from below with a pipe wrench or channel locks, and I'll have my recip saw on standby. I think it's the safest way to go with some alternatives in my back pocket.
Lesson learned- replace your shocks more often! These have 100Kmi on them and are long overdue for replacement.
Once the rear is done, I'll tackle the front.
Thank you all again for your help and suggestions.
Actually IMHO preparing the shock mounting threaded stems for removal should be the take away here. As I say liberally coating the threaded fittings with anti-seize before inserting them and threading the attachment nuts into place seems to work very well come renewal time. Whether its 50K or 100+K miles bare steel threads tend to rust over quite quickly regardless what the renewal interval.
Yep, I have rear A/C as well, but those lines are not as in the way as all the fuel lines. Yeesh.
I hate to admit it but it's been nearly a year since I've looked at it and have been putting off dealing with it since I don't have a great place to work on it. But I do remember something making access difficult....LOL.
I may give the bolt extractor sockets a try. I have a small pipe wrench and Vise-Grips, so I hope I can get a grip on the rod. My buddy has a reciprocating saw, so I may end up having to use that. Good luck with yours.
Reason: add info
Not to harp on the topic of shock brand selection but this operation is where the wrench flats at the bottom of the top shock stem comes in very handy. I am guessing this works on every E-Series from '97 through the 2013's and onto the cutaway's as well
