E450 fuel gauge
E450 fuel gauge
I’m new to the forum so sorry if this is in the wrong place. But I have a 2002 E450 with the 7.3 that had a non working fuel gauge. I pulled the sender, resoldered a bad wire and now I get the proper reading from 16-160 ohms. When I plugged it back into the truck (outside of the tank for testing) the fuel gauge doesn’t move. But if I hold the sending unit in a certain spot, then turn the key on the gauge moves to that spot, but any movement after that and the gauge doesn’t move until the key I recycled at which point it stays in the new spot regardless of where the sensor is positioned. Any input thanks!
stephen.andersen
08-05-2018 04:48 PM
robertrhyde
28
03-11-2011 01:26 PM
