The bolt is seized inside the steel bushing. If a couple of swings with BFH will not move it then you will have to cut the bolt off and replace it with a new one
Thanks for the tips. I'll get that a shot. I have the nut off and pounding isn't budging it. You mean cut the head off the bolt? I guess I don't see what good that would do. Maybe I'll just keep pounding LOL
Soak it with some WD or PB really good, let it sit for a few hours or even overnight. Use a little propane torch and heat the bolt. Proceed with the BFH and maybe a punch.
Your hammer isn't big enough obviously. I just did mine and it took lots of PB and a 3 pound sledge hitting it at least 20 times before mine broke loose. Keep swinging!
If you cut the head and the tail of the bolt off, spread the mount slightly the shock will come right out.
OR.... you cut between the shock bushing and the shock mount, then the shock falls out but you have to deal with burning rubber
Try alternating heat and ice cold on the bolt for 4 or 5 cycles, then pb blast it, let it set and then use the BFH.
The alternating hot and colt cycles cause it to expand and contract rapidly which breaks loose the rust somewhat allowing the pb blaster to get into the space.
I agree w/ the heat / cold thing. Those cans of compressed air if held upside down will spray out the chemical and freeze it...maybe freeze it w/ that, then torch it, and repeat a few times?
