2000 E350 rear upper shock bolt stripped
Old Sep 27, 2022 | 09:52 AM
bengineer's Avatar
bengineer
Hey everyone, 2000 E350, 355K mi, replacing the rear shocks, got the pass side out (yowch, what a job), and trying to get the driver's side out. I was able to get the bolt most of the way off, lots of penetrating spray. I got the bolt nearly off, but it finally relented and rounded off.
Looking for advice at this point- it's tough to get a saws-all in there and besides it's very close to the fuel tank and any slips would be disastrous.
I've also thought about trying to get a dremel tool with a cutoff wheel to see if I could cut enough of the nut to get it to break off. Not sure if a lot of how many sparks may be thrown in that move, but it seems like it would only take a sec to do if I can get it in that small space.
Another thought it to try to get some vice grips on the top nut somehow and perhaps a pipe wrench on the upper part of the shock and work it off.
Anyone else been though this? Good news is the new shocks go right in.
Thanks as always,
Ben
Old Sep 27, 2022 | 10:51 AM
tabijan's Avatar
tabijan
Can you slide a metal panel to shield the fuel tank? I’m guessing you’re on your back on the ground rather than a lift. That makes hosing down the tank to suppress sparks messy.
Can you get a nut splitter in there?
Sixto
07 E350 5.4 183K miles
Old Sep 27, 2022 | 12:52 PM
Mike1's Avatar
Mike1
That was going to be my suggestion also to use a nut splitter if there's room. Either that or use a biter bit to go over the rounded nut .
Old Sep 27, 2022 | 05:59 PM
Conanski's Avatar
Conanski
Time to get mad at it and stop being so patient. I saw a u-tube video where a guy simply grabed the loose end of the shock and bent it until the shaft broke off.
Did you remove the spare tire to get some more room to work at least?
Old Sep 28, 2022 | 04:24 AM
JWA's Avatar
JWA
Since I use Bilstein I'm sure that would not be an easy task!
Without the spare in the way there is an acre of room on top of and behind the cross member. I've replaced a few rear shocks that way.
A good idea is when the replacement shock is installed liberally coat the whole upper stud threads with anti-seize. I also look for shocks that have the hex fitting at the top of the shaft where a back up wrench can help removing the nut. That feature is just one reason I run Bilstein shocks.
Old Sep 28, 2022 | 09:27 AM
econo93's Avatar
econo93
Originally Posted by Mike1
....... to use a nut splitter if there's room. Either that or use a biter bit to go over the rounded nut .
What is a 'biter bit'?
I have the same problem as Ben and it's worse because it has rear AC.
Old Sep 28, 2022 | 10:23 AM
tabijan's Avatar
tabijan
x2 on Bilsteins for usable wrench flats. Monroe Magnums have wrench flats but they’re 4mm thick and I don’t have flat wrenches.
Sixto
Old Sep 28, 2022 | 12:19 PM
Mike1's Avatar
Mike1
Harbor Freight calls them a bolt extractor.... The go over the rounded head and when pressing downward they bite into the head and grab it.
https://www.harborfreight.com/38-in-...ece-67894.html
Old Sep 28, 2022 | 01:00 PM
tabijan's Avatar
tabijan
You might need an extractor with external wrench flats to clear the top stud.
Sixto
Old Sep 29, 2022 | 05:10 AM
JWA's Avatar
JWA
Rear A/C doesn't affect rear upper shock attachment. The lines for factory rear heating/cooling are outside the frame rail, shock mount inside.
Frankly the easiest solution is using a reciprocating saw---they tend to eat through the shock stem in a damn hurry.
Old Sep 29, 2022 | 10:57 AM
wwwheaty's Avatar
wwwheaty
Hot wrench
Old Sep 30, 2022 | 05:04 AM
JWA's Avatar
JWA
Originally Posted by wwwheaty
Hot wrench
You're welcome to go at this any way you choose but for me working that close to the fuel tank seems downright foolish. Not everyone has a "hot wrench" yet I'll bet most of us have access to a reciprocating saw and for this task they're far, far more safe to use.
Old Sep 30, 2022 | 06:59 AM
Mike1's Avatar
Mike1
If he's going to go at it with a saw which he already said wasn't much room, he'd probably be better off using a dremel with a right angle attachment with a cutoff wheel..
Old Oct 1, 2022 | 04:25 AM
JWA's Avatar
JWA
I've removed shocks on three different E-Series from 2000 to 2005 using the method I describe BUT the spare has always been removed first. A Dremel tool is great for a lot of things but nibbling away at a shock stem would work but the reciprocating saw is easier and faster too.
If this guy claims there's no room I have to think that's from a lack of trying---the chassis of the 1997 through 2013 full body E-Series are all pretty much the same, cannot envision how a stock chassis would be so much trouble.
Old Oct 18, 2022 | 08:42 AM
bengineer's Avatar
bengineer
Sixto
Thank you for your reply, and sorry for the delay in getting back to you. Yes, I'm trying to work on it on the ground, It feels more secure that way. I like your nut splitter idea, I'd forgotten all about those, and I think there is enough room to get one in there, so I'll give it a try.
Another thought I had was to get a piece of wood in there, get some vicegrips on the top bolt, then wrench it off from below with a pair of channel locks or a bigger pipe wrench. My 2" pipe wrench is not quite big enough to do the job.
Thank you again!
Ben
