Sponsored by: Real Truck
Shocks help
Old Aug 20, 2010 | 06:47 PM
aceltx09's Avatar
aceltx09
Shocks help
I have an 01 f250, the rear shocks (the top nut) is so rusted I will probably have to cut it off, I wouldn't have a problem but the bolt is a stud on a brackett, What do I do then replace the entire brackett. Anyone else run into this and have a different solution???
Old Aug 20, 2010 | 06:51 PM
QwkTrip's Avatar
QwkTrip
I remember removing a bolt, not a stud, when I changed my shocks. Maybe you just need to give it a good whack with a hammer to knock it out.
I couldn't remove a lower bolt on a rear shock. I used a sawsall with a metal cutting blade to saw through the bolt in a few seconds. (Don't even bother with a multi-purpose blade. It just won't work and you'll waste an hour of your time.) I bought a new bolt from Ford. Not a problem.
Old Aug 20, 2010 | 06:54 PM
aceltx09's Avatar
aceltx09
I'm not worried about getting the nut and bolt offf but its not abolt it is a stud that is welded or part of the top brackett so when I cut the stud there will be nothing to attach new shock to and I cant use a new bolt because the cut stud is in there and part of brackett
Old Aug 20, 2010 | 07:09 PM
aceltx09's Avatar
aceltx09
Does anyone know if it is part of the brackett or am I not seeing through the rust correctly and it can be banged out
Old Aug 20, 2010 | 07:26 PM
QwkTrip's Avatar
QwkTrip
If there is a hex shaped head for a wrench on the end then it is a bolt. If it is a round head then it is a stud, or has splines to the bracket to keep it from spinning.
Old Aug 20, 2010 | 07:30 PM
aceltx09's Avatar
aceltx09
Ya its a round head thats why i'm confused if it is actually part of the brackett or it can be banged out once I cut nut off. I'm just afraid to cut it cause the if it is part of brackett I will not be able to replace with new nut and bolt.
Old Aug 20, 2010 | 07:47 PM
QwkTrip's Avatar
QwkTrip
I totally understand your concern. Keep this thread top on the list and hopefully somebody with greater knowledge will reply. By the way, I should have stated earlier that I don't have a fool proof memory.
Also, you'll want an impact wrench for the front top mounts. Getting the stockers off is easy enough. But the new shocks probably won't have the center key in the shaft to hold it still while you tighten the nut. I never owned an impact wrench until I moved to the midwest. The rust here is terrible and I use it all the time.
Old Aug 20, 2010 | 08:14 PM
aceltx09's Avatar
aceltx09
Thanks anyways qwktrip hopefully someone will know really getting aggravated wish they just put a friggin hex bolt on
Old Aug 20, 2010 | 11:09 PM
QwkTrip's Avatar
QwkTrip
For what it is worth, when I did the exhaust system on my truck I ran across the same thing on a exhaust hanger. It was a bolt with splines that fitted into the metal bracket. I'd assume the engineers kept using the same idea over and over again and that the shock mount is the same. If you don't see any weld beads then it's not welded.
eddie a
New Member Introductions
Jun 2, 2013 08:11 PM
lisagoud
Nov 26, 2011 10:08 AM
captbo
1966 - 1977 Early Broncos
13
Jan 25, 2011 03:20 PM
aceltx09
Modular V10 (6.8l)
Jan 12, 2011 08:55 PM
aceltx09
Aug 21, 2010 08:13 PM
