Injector codes
Old Sep 26, 2022 | 07:00 PM
  #46
xcrsp440's Avatar
xcrsp440
I would watch that Diesel Tech Ron video again. Then try and find a scanner that will display the values needed to start. If those are all acceptable, then start digging farther, like bad injectors. And if you need parts, don’t order online except for a ford dealer. Only motorcraft.
Old Sep 27, 2022 | 09:46 PM
  #47
blicharski1989's Avatar
blicharski1989
  1. P0098 is the OBD-II generic code indicating the engine control module (ECM) has determined that the intake air temperature sensor 2 (IAT2) has an open circuit in the sensor circuit. use your software to confirm your IAT2 sensor is OOR.
Old Sep 27, 2022 | 09:50 PM
  #48
blicharski1989
P0270 and P0278 are cylinder 4 and 6 contribution codes. Could be bad injector, FICM harness, high pressure oil issue.
we really need more diagnostic information. Do a video and post it to YouTube
Old Sep 28, 2022 | 07:39 AM
  #49
bismic's Avatar
bismic
Also - P0102: MAF sensor circuit low input detected (voltage less than 0.35V). Open circuit in the MAF V-Ref (vref) circuit or possibly a PCM short to PWR GND or signal -return circuits.
Tell us what kind of phone you have .............
thomble17
Sep 5, 2021 07:55 PM
Apocalypse
Jul 21, 2017 03:10 PM
cabloom300
Dec 27, 2012 04:55 PM
buckweet1980
Feb 5, 2011 11:10 AM
aocabrown
Feb 13, 2008 05:34 PM
