7.3l misfiring, codes:
Old Sep 5, 2021 | 06:39 PM
thomble17's Avatar
thomble17
Trailering
Hi, so i posted a thread here already abt my truck misfiring already, it’s a 7.3l Excursion. All signs pointed at the uvch, i ran an injector buzz test and it said injector no. 7 high to low side open, so i replaced the uvch with no luck, i ran another buzz test today and now it’s says 3, 5, and 7. i was also looking at codes and i have a code for idm, P1316. i also did not replace the connector going into the harness but will be tmw. any ideas? i’m pretty stumped and don’t wanna shell out the money for injectors based on a hunch, thanks you!
Old Sep 5, 2021 | 07:13 PM
Old and soft's Avatar
Old and soft
The tech folder above has hiding in there somewhere how to test uvch,and wiring harness with a meter. Solid troubleshooting, no cost if you own a meter. Should help pinpoint the problem.
Old Sep 5, 2021 | 07:55 PM
udsuth78's Avatar
udsuth78
Yep Old and soft is right(the innuendos just write themselves on that screen name), the tech section has it all. I would start at the 42 pin connector checking continuity to the injector harnesses. If those are good yhou can check resistance on the solenoids which should tell you if they're hooked up and if solenoids in spec. If those all pass then you're backtracking to the IDM and connector. Hopefully that link posts for the 42 pin map.
cutlass
13
Mar 11, 2024 11:59 AM
dbarnett42
Oct 5, 2011 06:53 PM
jmaskew
Aug 21, 2011 05:47 AM
nissandoc
Mar 18, 2007 08:54 AM
mudinford
Jul 27, 2004 09:01 PM
