2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Trailer safety/chain hook woes
Old 08-23-2022, 04:37 PM
Lux194's Avatar
Lux194
Lux194 is offline
Originally Posted by Frisbee_WaffleSnatch
Are these 1/2”? Does anyone know if that’s the correct size? The capacity is plenty but wanted to make sure I got hammerlocks that fit the hitch. Thanks!
yes, mine are 1/2 inch.
  #47
Old 08-24-2022, 03:37 PM
svtride's Avatar
svtride
svtride is offline
I went with USA made "NOS HAMMERLOK 1/2" MECHANICAL COUPLING LINK WITH STUD ASSEMBLY - YELLOW". I don't trust the metal in the off-shored hammerloks or can't confirm COO.
https://www.ebay.com/itm/153492272187
The following 2 users liked this post by svtride:
  #48
Old 08-24-2022, 04:27 PM
Compression-Ignition's Avatar
Compression-Ignition is offline
Home Schoolin' Dad
Originally Posted by chadstickpoindexter
Edit to add: So, which hammerlocks is recommended for these hitches? Like I said, there are so many brands, and then ratings...
I went nuts and grabbed (2 each) 3/8”, 1/2”, and 5/8”
Crosby lok-a-loy
No more fiddle farting around with the dang hooks. I now own the trailers I need, but for a while their I was renting and the stupid design of the hook eye was frustrating the heck out of me. Some hooks would go straight on, and some most definitely would not. I don’t have to worry about it now. Anything I would need to tow will fit served by my plethora of hammerlocks.
1/2” is the size you’ll most likely use most.
The following users liked this post:
  #49
Old 08-24-2022, 04:49 PM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is offline
Received 2,789 Likes on 1,353 Posts
  #50
Old 08-26-2022, 11:04 PM
ttavasc's Avatar
ttavasc
ttavasc is offline
I also went with the "Hammerlock" solution - 1/2" Grade 80 Alloy Coupler 12K WLL from AutoHauler Supply. Used a portable vise to press them on - took all of 5 minutes. They even include this sentence in their description of the product - "This is a popular product for people trying to find a way to get their safety chain hooks to fit the new F-250 hitch"
  #51
Old 08-26-2022, 11:34 PM
71stang99's Avatar
71stang99
71stang99 is offline
Temporarily Deactivated
3" receiver two trailers and could the attachment points be better like on my 09? sure but they still work well enough.
  #52
Old 08-27-2022, 12:49 AM
Y2KW57's Avatar
Y2KW57
Y2KW57 is online now
Received 3,445 Likes on 1,808 Posts
The following 5 users liked this post by Y2KW57:
  #53
Old 08-27-2022, 01:12 AM
willynilly's Avatar
willynilly
willynilly is offline
Originally Posted by BigTexDiesal
Classic idiot Ford. 6 years of the same ineffective safety chain attachment design requiring paying customers to find a band aid. Sounds like a good lawsuit if an accident occurs and customer had to jerry rig the Ford design to connect standard safety chains. Never buy another Ford, they just don't get it.
boss has new ford company truck. everytime i walk by and see that stupid hitch i shake my head
  #54
Old 08-27-2022, 02:25 PM
River Wild's Avatar
River Wild
River Wild is offline
I shake my head when I see all the junk people buy to hang on their hitched instead of using a real hook on the trailer end like a couple posts above. Hell of a lot cheaper too and takes maybe 5 min to swap them out. There is nothing wrong with the hitch on these trucks at all.
The following 4 users liked this post by River Wild:
  #55
Old 08-27-2022, 03:20 PM
Ltngdrvr's Avatar
Ltngdrvr
Ltngdrvr is online now
Received 3,389 Likes on 1,793 Posts
Well, think what you will, but all the trailers I pull don't belong to me, not my prerogative to change the hooks on the safety chains. So before I put a couple of shackles on my hitch, many times the chain hooks would not latch onto the receiver holes correctly, now there is no issue.
  #56
Old 08-27-2022, 08:17 PM
dieseldrew's Avatar
dieseldrew
dieseldrew is offline
Originally Posted by cficare
You'd be willing to gamble on someone's life with those POS's ?
Stay the hell away from where I live !
The following 3 users liked this post by dieseldrew:
  #57
Old 08-27-2022, 08:21 PM
dieseldrew's Avatar
dieseldrew
Sad stubborn way to think !
You pull a trailer, anyones trailer and ultimately you are the one responsible for doing "it" safely, nobody else !
  #58
Old 08-27-2022, 09:43 PM
Ltngdrvr's Avatar
Ltngdrvr
How is my way of thinking sad or stubborn???
I fixed my chain connection issue with the shackles, which are quite a bit stronger than the chains on the trailers, as safe as it can be.
The following 3 users liked this post by Ltngdrvr:
  #59
Old 08-28-2022, 07:44 AM
cficare's Avatar
cficare
cficare is offline
IIRC their breaking strength is around 11,000 pounds each. Been to Bradford ... lived in Lock Haven back in 1959.
  #60
Old 08-30-2022, 09:21 AM
NeverboughtanFseries's Avatar
NeverboughtanFseries is offline
lol.
Those are very very strong.
Quick Reply: Trailer safety/chain hook woes
