Trailer safety/chain hook woes
#61
Indeed they are. I do tree work on the side and use steel carabiners with my rigging gear, but all my life-support carabiners are aluminum Petzl units ... rated at 27Kn (6,000#). Gotta' keep the life support gear separate from the rigging gear, and it's real easy to identify where each carabiner is used when they're different materials.
#62
I shake my head when I see all the junk people buy to hang on their hitched instead of using a real hook on the trailer end like a couple posts above. Hell of a lot cheaper too and takes maybe 5 min to swap them out. There is nothing wrong with the hitch on these trucks at all. ![Spanking](images/smilies2/spanka.gif)
#63
There are plenty of complaints about GM's hitch chain configuration too. There must have been some issues with the old simple style failing. I would like to see a dual-purpose set of tow hooks back there, bolted securely in place, but I know that would add quite a few more bucks to build compared to the stamped and punched steel they all use on the hitches today.
#64
A carabiner is not the right way to connect your safety chains to your pickup. Could they work? Sure. But it’s kinda like needing to use the brakes quickly on an F-150 towing 30k. Everything was kinda sorta fine until you actually need to stop abruptly.
For those of us that take issue with the chain connections on the Ford hitch and chose hammerlocks, the reason we did so is the hammerlock is going to be as strong or sometimes stronger than the chain/hook it is connecting. They don’t require any mental gymnastics where you have to tell yourself these should be good enough because _____ failure method is really unlikely.
Having said that life is full of risks, do whatever you please. It just seems like if we say nothing we are helping to hold something up that does not even remotely represent best practices.
WLL
Shock Load
Breaking Strength
Torque Load
All these terms mean something.
WLL
Shock Load
Breaking Strength
Torque Load
#66
The following users liked this post:
#67
The following 2 users liked this post by ATC Crazy:
#68
Put your flame suit on.
#69
#70
#71
#72
#73
WLL
Shock Load
Breaking Strength
Torque Load
WLL
Shock Load
Breaking Strength
Torque Load
And safety chains aren't for abruptly stopping. They're for keeping your load attached to the tow vehicle. Brakes are for stopping abruptly.
#74
I was using the F-150 towing 30k as a metaphor explaining that it can be done, but isn’t right. I didn’t say the chains were for stopping abruptly.
#75
The rating dictates the guarantee of performance, not some arbitrary situation that you've constructed in your mind.
your metaphor was poor and inappropriate.
