Drifting left-alignment experts needed
Old Aug 13, 2022 | 07:50 PM
  #31
clayton.boyle's Avatar
clayton.boyle
Originally Posted by honda250xtitan
is there a schrader valve on the 5100? a quick tap to release some pressure then try again. Dont use a tire gauge, there isnt enough volume in the shock to do use those.
dont think it does I will look though
Old Aug 13, 2022 | 07:51 PM
  #32
clayton.boyle
Originally Posted by speakerfritz
Is your damper expands it’s not a damper.
if you want more caster and don’t want to s req up your camber….there is only 1 way of doing that…..pinion arm drop bracket . They come in different drops.
id have to agree. I’ll have to see what bilstein says about it I guess
do you mean pitman arm drop bracket?
Old Aug 14, 2022 | 09:56 AM
  #33
kylant's Avatar
kylant
Originally Posted by clayton.boyle
what was the cause of your left pull
here is my thread. the cause is at the end
https://www.ford-trucks.com/forums/1...-drifting.html
Old Aug 14, 2022 | 12:53 PM
  #34
honda250xtitan's Avatar
honda250xtitan
bilsteins are monotube shocks, so its high pressure, meaning theyre hard to compress. it could be pushing. I'd assume bilstein runs them at lower pressures for stabilizer duty but i dont know. i dont have issues with my single fox stabilizer though. same idea, same design. prolly alignment, did you ask the shop after you noticed it pulling?
Update
pulled the bilstein 5100 steering damper, took it for a spin around the block. BINGO!! Seemed to track straight maybe a touch right now due to crown on road. Got back and compared it to the stocker…stocker stays where you put it where as the bilstein seems to want to return to full extension, hence pushing my truck to the left. Threw the stocker back on will try it on our road trip tomorrow and report back.
not even a thanks! lolol jk
Old Aug 14, 2022 | 03:02 PM
  #35
clayton.boyle
appreciate it! Still find it hard to believe and maybe I should take it up with bilstein.
haven’t had it on a hold drive yet to verify but I will
Old Aug 22, 2022 | 02:59 PM
  #36
clayton.boyle
ANOTHER UPDATE
I removed 1.5" level, with stock stabilizer. still have 2.3 and 2.6 shims in. Checked my toe and set it to 1/16 to 1/8th in. The truck seems to drive really nice again other then small steering wheel wobble at 60mph plus.
Going to drop two front tires off for a roadforce balance tomorrow and see what that does.
Id say the truck almost steers right a little bit now, I may throw the bilstein 5100 damper in again that was steering me left and see if that counteracts my slight right
Do you think me removing the 1.5 level is warrant enough to bring it in for an alignment check again??
old442
Aug 26, 2023 06:35 AM
Gavin6.0
Jun 14, 2022 07:14 PM
MB1776
Mar 30, 2021 02:44 PM
Deagle12
Oct 21, 2017 10:20 PM
Isaac122752
Feb 21, 2008 10:07 PM
