Drifting left-alignment experts needed
Old Aug 11, 2022 | 11:09 AM
morehouse7's Avatar
morehouse7
Originally Posted by clayton.boyle
I know little about alignments, can the tech add caster to driver side without changing shims?
No, they would have to change the driver side shim.
Old Aug 11, 2022 | 12:28 PM
clayton.boyle's Avatar
clayton.boyle
what can I add on top of these shims to get my caster up a little higher. Is it worth me grabbing another 2.6 and throwing it in drivers side to see if it tracks better
Old Aug 11, 2022 | 12:44 PM
Sport45's Avatar
Sport45
Drive it without the steering stabilizer for a bit and see if it still pulls. It’s a cheap way to see if it’s the stabilizer or the alignment.
Old Aug 11, 2022 | 02:40 PM
speakerfritz's Avatar
speakerfritz
great idea
Old Aug 11, 2022 | 02:45 PM
speakerfritz
Nothing
its really a bushing
think of it as a ball with a stick through it.
the bushings come in different axial alignment. It changes the Angle of the hub ball joint.
one quadrant it adds caster but screws up camber
one quadrant subtracts caster and screws up camber
one quadrant adds cqmber but screws up caster
one quadrant subtracts camber and screws up caster.
Old Aug 11, 2022 | 03:10 PM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
I assume you switched front tires and test drove again?
Old Aug 11, 2022 | 03:28 PM
clayton.boyle
lots of ideas will try that too
Old Aug 12, 2022 | 06:44 AM
Joe T's Avatar
Joe T
So you have 1/2” leveling kit or 1.5 because if you have those snow plow springs you already are 1 inch over stock.
You should get a trackbar drop bracket, they are on Amazon.
2” should be close enough if thats the only one available.
Can you not see your axle being way out? Is it not “dog walking”?
Do that and realign it?
Old Aug 12, 2022 | 05:40 PM
clayton.boyle
ya I have 1.5” level on top of snow plow springs.
The axle is shifted to the driver side a bit yes. Will grab a drop bracket and see how that does.
Old Aug 12, 2022 | 06:17 PM
Sport45's Avatar
Sport45
Have you tried driving without the stabilizer? I always like to try the free and easy stuff first.
Old Aug 12, 2022 | 09:36 PM
clayton.boyle
Update
pulled the front tires tonight
checked the brakes, not dragging good time to service the pins etc and swapped tires side to side
the front axle is definitely shifted to the drivers side from the level, trac bar bracket or adjustable trac bar going on at some point in time to correct that
pulled the bilstein 5100 steering damper, took it for a spin around the block. BINGO!! Seemed to track straight maybe a touch right now due to crown on road. Got back and compared it to the stocker…stocker stays where you put it where as the bilstein seems to want to return to full extension, hence pushing my truck to the left. Threw the stocker back on will try it on our road trip tomorrow and report back.
I would still like to see a little more caster to improve handling further. I haven’t seen shims bigger then 2.3 and 2.6. Are there such a thing?
Old Aug 13, 2022 | 10:14 AM
kylant's Avatar
kylant
the steering stabilizer could be causing it, looks like it may be on your truck
also your positive camber on the driver side, and higher caster on the passenger side could be a cause of the drift.
so many variables.
i had a pull to the left, finally figured it out. had nothing to do with alignment
Old Aug 13, 2022 | 04:50 PM
  #28
clayton.boyle
so many variables.
what was the cause of your left pull
Old Aug 13, 2022 | 04:54 PM
  #29
honda250xtitan's Avatar
honda250xtitan
Update
is there a schrader valve on the 5100? a quick tap to release some pressure then try again. Dont use a tire gauge, there isnt enough volume in the shock to do use those.
Old Aug 13, 2022 | 05:39 PM
  #30
speakerfritz
Is your damper expands it’s not a damper.
if you want more caster and don’t want to s req up your camber….there is only 1 way of doing that…..pinion arm drop bracket . They come in different drops.
