Transmission Fluid type?
Old Jul 14, 2022 | 08:36 PM
12characterz's Avatar
12characterz
Rehabbing a 91 E350 7.5l. I just replaced the radiator, and am looking to top off some transmission fluid lost in that process.
I have the factory specs from ALLDATADIY, and that says type F. However when I search with the vehicle specs all the auto parts stores are showing Mercon V and the like.
Ive read that these two really aren't compatible, and I've also read that Ford stopped using Type F in the early 80s.
So with all this conflicting info I'm not sure what to do next, any ideas? Thanks!
Old Jul 15, 2022 | 03:59 AM
JWA's Avatar
JWA
Post this same question in the sub-forum for Transmissions.
Old Jul 15, 2022 | 08:26 AM
12characterz
Ok I just did that, thank you.
Old Jul 27, 2022 | 04:11 PM
icrman's Avatar
icrman
deleted some how on wrong thread?
Old Jul 27, 2022 | 05:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Ford stopped using Type F in 1977. MERCON V is the proper fluid for your transmission.
Old Jul 28, 2022 | 06:43 AM
manicmechanic007's Avatar
manicmechanic007
If you can buy a nice pan for it with a drain plug
My Hughs was quite expensive
I figure it is worth it if it saves me time on a rebuild
Here is a picture, get one if you can
Old Jul 28, 2022 | 06:44 AM
manicmechanic007
Old Jul 29, 2022 | 06:20 AM
JWA's Avatar
JWA
When it comes to transmission pan drain plugs I like this type: Quick Changer #71314 Its somewhat between no drain plug at all and perhaps a more expensive increased capacity pan. It's the same size and thread as the engine oil drain plug which I also use one of these. They thread right into the factory oil pan hole.
When installing in a transmission drain pan I drill a suitable hole, insert the Quick Changer and secure it all in place with #271 Loctite (red) and a heavy hex nut in the 14mm-1.5 size to make sure it never leaks or comes loose.
A few photos showing these in use:
Worth looking into as a one time purchase.
HTH
Old Jul 29, 2022 | 08:42 AM
12characterz
Awesome! I was wondering if I could just drill in a plug, thanks for the tip!
HomerCamper
26
Dec 6, 2017 05:12 AM
yabadaba
25
Aug 1, 2014 09:07 AM
04F-250mark
May 5, 2009 08:51 AM
shotgun_000
Jan 28, 2006 06:22 PM
jimpennycuff
Oct 19, 2005 08:25 AM
