Towing in mountains - problem or no?
Old May 2, 2022 | 09:54 PM
EJHiker's Avatar
EJHiker
Exclamation Towing in mountains - problem or no?
I have an 2020 F-450 and am towing a 13k fifth wheel. While climbing long 4 - 6% grades the truck seems to lose power s while in 7th or 8th gear, and doesn't downshift. I am using tow-haul, and RPMs stay around 2000, but the engine sounds like it is revving but doesn't downshift. It has happened 3 or 4 times, each time during a long climb while towing. I have little experience with mountain driving and don't know if this normal, or signs of an issue - would appreciate guidance or questions to help me know how to better observe and describe this concern.
Thanks!
Old May 2, 2022 | 10:47 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Sounds like it is revving but doesn't downshift and remains at 2,000RPM?
Are you hearing the radiator cooling fan?
It will cycle on and off as needed to keep the engine cool. Sounds kind of like someone slowly turns up a vacuum cleaner and then after a bit they turn it back off again.
If this sounds right, don't worry, it's just doing its job.
Last edited by CathedralCub; May 2, 2022 at 10:56 PM. Reason: Added the last two paragraphs.
Old May 2, 2022 | 10:57 PM
00t444e's Avatar
00t444e
Remember you can downshift it manually if you want to.
Old May 3, 2022 | 08:49 AM
acadianbob's Avatar
acadianbob
Yep! I use manual on passes for the control that I want.
Old May 3, 2022 | 09:43 AM
RA12726's Avatar
RA12726
Banned
This^^. If the engine is remaining at 2,000 RPM, it's not revving and you are hearing the fan. My truck starts screaming like a banshee (pulling a 15K fifth wheel up and down grades) when the fan clutch engages completely. I asked about it on the forum here last year... it's just doing its job.
Rob
Old May 3, 2022 | 10:51 AM
scraprat's Avatar
scraprat
Top Answer: 5
Rob
The first time it happens it's like "what the...", after realizing it's normal, phew...
Old May 3, 2022 | 03:57 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
As others have said, what you are hearing is just the fan kicking in and doing its job.
My 2000 7.3L diesel tows steep and long grades out west in CO, ID, WY, etc and the fan will kick on at times too during the summer in June, July and August. Your 2020 F-450 should do just fine with those grades and that weight behind it. Just keep an eye on the temperatures and if you see something an abnormality then take action.
Enjoy the journey and let the truck do what it does, get you there!
Old May 3, 2022 | 08:42 PM
EJHiker's Avatar
EJHiker
Thanks everyone for the info- it makes sense that it’s the fan… and is a relief! I appreciate the help!
Old May 4, 2022 | 02:51 PM
jollyrogr's Avatar
jollyrogr
The engine fan on a diesel is loud and takes a decent amount of power to run.
Old May 4, 2022 | 06:56 PM
senix's Avatar
senix
normal, I use tow/haul and let it do its thing. Use cruise most of the time.
If you really want to know what is going on, something like an idash to monitor will tell the alot.
Old May 6, 2022 | 06:31 PM
traveldawg's Avatar
traveldawg
To monitor the fan operation one can always use a ForScan monitor. I keep an eye on mine along with a few other temps and things (like when a DPR region is active).
Work Truck Fanatic
All Things Towing
Jul 22, 2020 08:22 AM
tjcoker
Mar 18, 2008 07:39 AM
whattatruck250
Aug 5, 2007 10:52 AM
nymo
All Things Towing
Jul 11, 2007 12:03 AM
DPtoo
All Things Towing
Apr 13, 2002 04:29 PM
