View Poll Results: at 25% oil-life today
do nothing till the oil-life indicator says to
29
28.16%
change filter only & do the full oil & filter change when the oil-life is done
0%
change filter and oil early, if it bothers you that much
74
71.84%
Voters: 103. You may not vote on this poll
Oil change concerns
Old Mar 28, 2022 | 08:22 PM
  #76
aklim's Avatar
aklim
Originally Posted by GraM4
The ONLY way you'll actually know if the oil is any good, is to take a sample and send it off to the lab...
But, to do a sample properly, you have to collect it mid-pour out of the pan.. in which case, you've drained roughly half the pan's capacity.. may as well do an oil and filter swap while your hands are dirty.
Then when you get the results back, you'll know if you wasted your money changing it early, or prevented a fiasco because you got dirty oil out. The onboard OLM is only a timer, it doesn't know if you started your engine at -30*c not plugged in, to drive it 5 miles before shutting it off for there day, or if you put a 20,000 lb trailer on it and tugged it through Death Valley in August.
Don't go by that. Go off your usage, and mileage. Yes newer oils are better than from 30 years ago. They have more additives, keep things cleaner inside your engine, and better lubricated. Part of the additives being better, is they hold more particles in suspension, and some of them are smaller than the microns in your filter.
I know I'll be doing my first oil change between 1500-2000 miles, and the second about 4000 later, then 7500 after.
Probably overkill, but it's my truck, and that's what I've had success with in the past with these 6.7's
Side note, I grew up in PG, still have lots of family and friends there, one in fact works at the dealership you must have gotten it from. Good luck with the new rig
Is it just a timer going off the number of minutes of running? I think it takes other things into consideration. The ECM knows what the truck is doing. Even back in 2001, the ECM knows that I am loading the engine up and adjusts the MPG counter accordingly. So yes, if you want to know how good the OLM is, you take a midstream of oil so you can tell what to do in the future as far as trusting the OLM.
Old Mar 28, 2022 | 08:27 PM
  #77
aklim's Avatar
aklim
Originally Posted by Ding126
I dont know why people ask these questions. Read the manual !! I decided to change my oil at 5k miles regardless and then a year later my truck told me to change oil due to age.
This is like taking a crap and asking what TP to use and how many times should I wipe....Only you can decided
But if you use a bidet, you don't even have to wipe. They have toilets with a puff of air to dry your *** and water sprays for male and female.
Old Mar 28, 2022 | 08:30 PM
  #78
aklim's Avatar
aklim
Question about the OLM. I wonder whether there is a difference using Semi Synthetic vs Full Synthetic. My guess is that it was programmed for Semi so it might not realize, like MB might, that you are using full or semi.
Old Mar 28, 2022 | 09:16 PM
  #79
4wd6.7L's Avatar
4wd6.7L
From what I have read the gas engines have an OLM, or maybe more accurately an OM. An oil change reminder if you will. Based on nothing more than time and/or miles. Maybe that time and mile is based on semi-synthetic use, since that might be standard fill for the gas engines.The diesel has the IOLM, and nowhere does Ford say anything about oil type(synthetic, semi syn, conventional) being a factor. The 10w30 and 15w40 Motorcraft diesel oils are conventional, or at least there is no indication on the jug that says otherwise.
Old Mar 29, 2022 | 06:19 AM
  #80
philips's Avatar
philips
Originally Posted by 2021F350
I guess what I am really asking is, do you guys trust the oil-life remaining info and do you go by it... ???
The oil life monitor goes to zero % life remaining in 12 months on the gas trucks, it is not that smart. My truck is not my daily driver, and I only do about 6000 miles a year. I did an early oil change at 1000 miles, then an oil change at the 3000 miles interval, next oil change will be at 5000 mile interval, then I plan for the next oil change at the 7500 mile interval. I am using Blackstone to perform used oil analysis, once engine break in is completed, I will use their suggestion for oil change intervals, not the oil minder. Philip.
Old Mar 29, 2022 | 06:25 AM
  #81
zeroo's Avatar
zeroo
odd, they recommend going by the olm in the manual.
Old Mar 29, 2022 | 06:40 AM
  #82
shawnee1's Avatar
shawnee1
Just because the OLM goes to zero at 12 months does not mean it is not smart. Time since the last oil change is just one of the parameters that affect oil life.
Old Mar 29, 2022 | 06:57 AM
  #83
Mikelikesit's Avatar
Mikelikesit
I dont pay any attention to it with my own personal vehicles. I use full synth at 5000 miles. My first change is usually around 1000 or even 2000 miles to get any potential metal from break in out of the engine. Then I go to 5,000. Easy to remember for everyone in the family.
At work I have an 06 model GMC. Too old for me to trust the Oil life indicator. But miles are few so once a year.
I have a 2010 F-450 and a 2017 F-450 with V-10s. I use the indicator for them and trust it.... Or once a year. Its usually below the 5,000 but these trucks work hard at slow speeds and idle more than a personal truck.
The newer computerized systems take more info into account and I feel comfortable with that info.
Our Camaro has Gas DI which is supposed to push a lot of combustion by product into the oil. I changed it at 1,000 and in December I did the second change before covering it for the winter with only 3,000 miles. And I swapped out the factory fill in the rear as well. I dont care what the computer says... Even with the $8 a qt oil it requires 10 of.
I use the oil I believe is best at the time. Full synth. Right now in the truck Im using Valvoline. But no brand loyalty really. I use that in the Accord too.
Mobil 1 0w40 in the Camaro.
Old Mar 29, 2022 | 07:08 AM
  #84
RidgwaySD's Avatar
RidgwaySD
This EXTRA only changing the filter early idea, is just for this first oil change, at 25% oil-life left monitor... Then when it says oil-life left is zero% I would change the filter again, and the oil too... Doesn't seem that radical to me, It's an EXTRA step to make sure the filter isn't plugged from the extra brake-in crud that's in there but won't be in the later oil change intervals, thus I would change both at the same time then... It's basically, the same idea most of you have, of changing the oil and filter in the first 1,000 miles... Even thou the oil-life monitor says that the oil and the filter is good for another 95% of life... I'm just saying there in no reason to change the oil too, it's the filter that is/could be a problem if it plugs up totally, and bypasses the oil without filtering... JMO
The great part about all of this is that you have based it ENTIRELY on assumptions you have no evidence to support. The idea that the filter needs changing before the oil is preposterous, and you do not even understand why. The OIL carries the contaminates by design. The filter does not scrub the oil clean, it just removes the larger suspended particles. There is NO WAY your filter is plugged and bypassing without filtering unless you have had a major internal failure. Please show us where you have found evidence of oil filters being plugged and bypassing during regular oil change intervals. Sadly for your contention such evidence does not exists because you simply fabricated this problem in your mind and presented it here as if you found the magical solution for the non-existent problem. Congratulations, you have wasted a bunch of bandwidth over a false premise.
Old Mar 29, 2022 | 07:23 AM
  #85
chadstickpoindexter's Avatar
chadstickpoindexter
I changed my oil yesterday. I punched the filter to let it drain. After a while I felt like it was time to remove it… and a ton of oil still came out! I’m just curious to see how someone would change the filter only without losing a large amount of oil, as well as getting oil everywhere… and then still having to add several more quarts back in at least… I’d say either change it all now or wait and do it all later.
Old Mar 29, 2022 | 08:17 AM
  #86
drj564's Avatar
drj564
Change your oil at what ever interval gives you a woody. I changed mine early from the factory oil just to tell myself I did something good for the truck. THEN I went 9K miles and sent that oil to Blackstone. He suggested going to 11K on the next change. That was 95% pulling a 16K 5th wheel across half the country at 70+ mph. You can guess, assume and read all the posts you want about others opinions, or you can test your own oil in your own truck at what ever interval you want to test at.
Edit: This is a Diesel.
Old Mar 29, 2022 | 09:30 AM
  #87
Ford Fx4's Avatar
Ford Fx4
Was that on MC 10W30 or had you switched to 5W40 for the Blackstone test?
Old Mar 29, 2022 | 11:56 AM
  #88
jollyrogr's Avatar
jollyrogr
The fact that it was worked hard is probably a good thing for the oil. Means you would have experienced minimal active regens and no interrupted regens, so minimal fuel dilution.
Old Mar 29, 2022 | 12:26 PM
  #89
drj564's Avatar
drj564
I switched to T6 10W40. Most of the time that’s all I can find around here when I need it.
Old Mar 29, 2022 | 12:44 PM
  #90
4wd6.7L's Avatar
4wd6.7L
17-19 had no mention of an OLM for the gas engine, not that I see in the manual, but I see that newer gas trucks do. What is interesting (if I'm looking at the right manual), and a little confusing, is that under the normal maintenance interval tables, it still gives a distance/hour/time change interval for gas. But with the diesel it says to go by the information display (with a note not exceed..). I wonder why the difference.
