Stranded: Transmission problem with codes
Old Mar 25, 2022 | 06:40 PM
TooManyToys.'s Avatar
TooManyToys.
I thought Warren was only doing local trans work. From Corey at CNCFab you can get Sam Wyse. Or take a chance on a lower mileage '05-'10 from salvage. The '6+ will need a converter change from my understanding, as well if you get the trans out of a gas motor, V10 recommended I believe.
It seems lately Ford reman trans are going the way of Ford reman diesel.
Old Mar 25, 2022 | 11:34 PM
High_HP's Avatar
High_HP
I will be putting in a new Ford brand cooler and possibly changing the radiator to avoid contamination from the radiator, remaining lines will get flushed best I can without access to a flush machine. Open to any suggestions/advice on sanitation procedures.
TMT, I read that as well about Warren, but they confirmed to me today that they are doing them in house currently, at least the stock+ 5r110w I inquired about. I looked at CNCFab's site and they have a header stating Sam's transmissions are 'at least 12 weeks' out, price jumped a good bit from where it used to be on them as well. I can wait maybe 3 weeks, but not much longer...rental cars be expensive these days
Old Mar 26, 2022 | 04:57 AM
TooManyToys.
Yeah, prices jumped! The 7.3L guys have more options, BTS, Woods....
That's what I meant about Warren, in-house.
Old Mar 27, 2022 | 06:26 PM
bismic's Avatar
bismic
If it were mine, I would change out the radiator also.
BTS does do 5R110's, but he is a long lead for one also.
Old Mar 29, 2022 | 08:45 AM
MisterCMK's Avatar
MisterCMK
I've had decent luck with salvage yard transmissions. I think I paid $900 for mine. That is a hell of a lot better than what some guys want for a built transmission.
Old Apr 17, 2022 | 07:07 PM
High_HP's Avatar
High_HP
Update: The Warren stock+ is in, finished today. Runs fine. The re-learn (shift flares) was a bit un-nerving even though I knew to expect it, first test drive is always worrisome after a big project. Took about 4-5 part throttle runs shifting from 1st-4th for it to start smoothing out, which it did each time. Still need to drive it some more. Changed the rear main seal (new style) as well, the $75 copy-cat tool on Amazon worked well and was constructed well, saved me from spending $200+ on the one from Freedom Racing that it copies. Hopefully this transmission holds up over the long run. Thanks for the tips everyone, they sure did help!
Skylaneman
Apr 17, 2022 06:57 PM
cdrich07
Jul 2, 2013 08:32 PM
RDC F250 7.3
Feb 24, 2012 09:58 PM
Jesse1989
1978 - 1996 Big Bronco
May 4, 2011 06:13 AM
Jason8705
Jan 16, 2006 09:13 PM
