03 6.0 suggestions
Old Apr 17, 2022 | 08:25 PM
Sooprdv3's Avatar
Sooprdv3
03 6.0 suggestions
Bought an 03 F350 dually for a very reasonable price knowing it may need injectors. Threw need batteries in(sitting 3+ yrs) got it running with a little ether but has no pedal. ICP numbers were considerably off and IPR was at 85%. Started to disassemble to perform an air test on the oil system,bought an import kit with IPR fitting and ICP fitting along with an IPR socket.I’ve also removed the turbo to replace some oil seals. Was looking for guidance as far as the air leak procedure and any other upgrades/maintenance items I should address now with it being apart. Not under the gun to get it done quickly. Thanks Dave
