6.0 block heater
Old Jan 19, 2022 | 09:25 PM
Baylinerchuck's Avatar
Baylinerchuck
6.0 block heater
Being in south central PA and experiencing colder temps I use my block heater a lot. Typically it keeps the engine 80 degrees to 110 or so depending on the temp outside. Really like having the instant heat and not having to wait to warm the truck. Not that it really needs it to start, it’s just nice. I work for a trucking company so I’m able to use the block heater receptacles at work, so the truck stays on the block heater a lot.
What is the life expectancy of a block heater? How hard to change if I ever need to? Any adverse affects to oil or anything else?
This is really just to satisfy my curiosity given I use the crap out of it.
Old Jan 20, 2022 | 08:16 AM
F350 1990's Avatar
F350 1990
The element gets contaminated with chem build (just like the one in your hot water heater), then pulls more current and the cheap wire (lower than req'd AWG) melts occasionally -- there were recalls and avoid (like the plague) the aftermarket junk.
Old Jan 20, 2022 | 08:52 AM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Drain coolant to replace block heater. It's pretty straight forward.
Old Jan 20, 2022 | 12:55 PM
TooManyToys.'s Avatar
TooManyToys.
Let's try something helpful.
File Type: pdf
File Type: pdf
Old Jan 20, 2022 | 09:10 PM
Baylinerchuck
Assuming from the illustration that this is at the rear of the block. Looks like an exhaust bellow in the figure.
Old Jan 20, 2022 | 09:19 PM
Baylinerchuck
yep, definitely stay away from the Chinese junk when comes to things like this on my truck. Especially considering draining the coolant down to change it. I guess just wait for it to fail and replace it when it does. Can’t imagine there would be too much contamination on it given the use of distilled water with the coolant. Only time will tell apparently.
Old Jan 20, 2022 | 10:05 PM
TooManyToys.
Correct. Above the starter. Not the most convent place.
Starter Removed.
Old Jan 22, 2022 | 08:28 AM
Baylinerchuck
Starter Removed.
Excellent information. I greatly appreciate it. I replaced my oem 6.0 starter with the much quicker rpm 6.7 starter. I had no idea that was the block heater. Knowing is half the battle.
Old Jan 24, 2022 | 11:12 AM
Yahiko's Avatar
Yahiko
Having the heater plugged into a GFCI outlet is something you do't hear a lot about. They do trip if you get a pinhole in the heater element jacket. So if you have it on a
GFCI and it keeps tripping take your meter and connect one lead to the truck frame and the other to one of the two hot prongs. You should see that the meter things it
open as it should be. If you get any resistance then the heater is likely bad. Also a good thing to check is the ground pin to the truck frame and that should show
a low amount of resistance.
If it fails either test them it's time to replace it and the cord.
Old Jan 25, 2022 | 07:59 AM
Baylinerchuck
Great information on testing the heater. I agree it’s definitely a good idea to have these on a GFCI. Both places I plug in are GFCI receptacles. Those who don’t have theirs on a GFCI can purchase an extension cord adapter that have them built in.
Old Jan 25, 2022 | 09:00 AM
TooManyToys.
Anything plugged in outside goes to a GFCI at this house.
Qwazert
6.2L V8
Jan 11, 2022 06:52 PM
EgonAngler
Feb 14, 2020 09:47 PM
Bota
Nov 16, 2012 07:05 PM
smithrock
Dec 9, 2011 03:37 PM
97 RED PSD
Dec 9, 2005 04:52 PM
