Block Heater ?
Old Nov 12, 2012 | 08:08 PM
Bota's Avatar
Bota
Block Heater ?
Hey guys, I am getting ready for winter and I have a ?. Does the Block Heater in 6.0 have Thermostat type setup or is it always on when plugged in? I always assumed it would be on when plugged in but now i'm not sure.
Thanks in advance.
Old Nov 12, 2012 | 08:26 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
They are on all the time, i use a timer to come on 3-5 hrs before starting my truck
Old Nov 12, 2012 | 09:05 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
^^^ agree.
They are on all the time, and are 1000w.
Timer is a good idea.
Old Nov 15, 2012 | 09:42 PM
Bota's Avatar
Bota
Thanks for the info, i went out and bought a timer and a good ext cord.
Old Nov 15, 2012 | 11:37 PM
Fulthrotl's Avatar
Fulthrotl
Originally Posted by amdriven2liv
^^^ agree.
holy cow.... it wouldn't be that hard to
set up a thermostat and a little ice cube relay
to keep the engine about 40 degrees....
i plugged mine in one cold night (for california)
and the next morning, the engine was hot....
now i know why... i figured it would have a T stat
built into it... 1 KW is 1 1/3 horsepower.
gad.
Old Nov 16, 2012 | 12:05 AM
amdriven2liv
gad.
Here is what I did a couple years ago::
This morning I plugged the block heater in. My Scangauge read 39 degrees.
1 hour later it was 80 degrees.
2 hours later was 94 degrees.
3 hours later it was 103 degrees.
4 hours later it was 110 degrees.
5 hours later it was 116 degrees.
Yes, 39 isn't that cold to start, but was interesting to see that it went from 39 to 80 in an hour.
Currently my oil temp in hour 3 is 77 degrees. It was 40 at starting point.
Oil temp after 4 hours was 91 degrees.
Thus the suggestion of a timer!
Old Nov 16, 2012 | 12:53 AM
hink10's Avatar
hink10
Good info!
Old Nov 16, 2012 | 01:22 AM
04badford's Avatar
04badford
Soo would this take the pressure off glo plugs in the morning and where would one find the hook up ,late model 04 6.0 350 .Thanks for the Input.
Old Nov 16, 2012 | 01:27 AM
amdriven2liv
I am sure it does. How much, how would one know! If I recall, the glow plugs are linked to oil temp (or one of the temp sensors) Don't quote me on that!! LOL (I'll need to go look again on this)
Your truck should have one. 05-07 were hit and miss, but 03-04 were stock installed.
First, you can feel just above the starter (passenger side) for the cord where it plugs into the block heater. It should be there, unless someone removed it before you bought it, assuming you haven't owned it since new.
They zip tied the plug end up real tight behind the bumper. If you stand looking at your truck, just to the right of fog light, or where a fog light should be.
It's hard to see. I looked 3 times before finding mine. I needed a flash light in the middle of the day!!
Block heater manufacturers do not recommend starting the motor when it is plugged in. Just saying.
Old Nov 16, 2012 | 01:37 AM
04badford's Avatar
04badford
Thank you , I never knew will check it out ,I do know on the front drivers wheel cover down by the splach sheild and frame little white connector about 2 1/2 '' just hanging there could that be?
Old Nov 16, 2012 | 01:46 AM
amdriven2liv
Well, I wont say it isn't. Someone may have decided to run it over there so they wouldn't forget to unplug before driving off!
I would be curious as to what that is hanging over there. Might want to trace it.
Old Nov 16, 2012 | 01:54 AM
04badford's Avatar
04badford
I'll try to trace and flash some pics dont look to be 110 plug , I bought the truck new in 04 , but had heads done with cab pulled just wondering if the connection could be pinched or ford fan it that way ? hummm, Thanks Amdriven2liv Scott
Old Nov 16, 2012 | 01:58 AM
04badford's Avatar
04badford
sorry my arturitis hit the wrong keys (ran it that way)lol
Old Nov 16, 2012 | 05:23 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
You may use 10-15 cents per hour to heat your engine, but you get cab heat almost right away. Plus it should be easier on your engine and batteries. I use a 3-4 hour timer when the temps are below 32.
Old Nov 16, 2012 | 06:29 AM
sammy77's Avatar
sammy77
I almost never plug my Truck in. I do have a remote start that I use everyday and let her run for 10min or so. However, in the winter, when we go up north(usually a week) I leave the truck plugged in 24/7 and unplug it to start it every day. It has gotten very cold there at times(-30F).
