Rough Cold Start
I'm also running Motorcraft 15W40. With the low mileage on your truck, I'd just make sure your glow plugs and relay are operational. 24 degrees isn't cold enough to have to plug in IMO.
In your first post you said you saw a voltage drop while the gps are on. And this may be correct but the solenoid could have worn contacts on the inside. Resulting in low voltage on the gp side. Here's how to test that voltage.
Key OFF:
-- Wire from the battery should read aprx. battery voltage, ~ 12.5V
-- Wire to the glow plugs should read zero
Key ON:
-- Wire from the battery will read SOME less, probably aprx. 11V
-- Wire to the glow plugs will read a little lower, but should be no more than 0.3V below the wire from the battery.
So if the DIFFERENCE between the two, WITH THE KEY ON, is more than 0.3V, replace the relay. It's still contacting, but supplying insufficient voltage to the plugs. DON'T bother comparing the battery side with the key OFF to the plug side with the key ON; that really doesn't tell you anything about the relay. If the difference between key OFF and key ON is a lot (like, it goes down to the 9-ish volt range), that would indicate weak batteries (poor-man's load test, basically).
Or the next cold morning jump the solenoid with a screwdriver. If it starts better you need a new solenoid. Buy a good one trombeta or motorcraft.
Key OFF:
Key ON:
So yesterday I went out and measured the resistance on the glow plugs. I was using my cheap Harbor Freight meter and due to the short cables I couldn't seem to find a real good ground, but I was able to consistently measure them all at 2.8 ohms.
I was measuring 12.1V on the GPR (I think, I didn't write it down) with the key off and 0V on the switched side. With the key on I was measuring 11.1V on the battery side and 10.3V on the switched side.
I had also plugged it in for just over 3 hours and it fired right up like it would during the summer.
This morning I got the same voltage measurements so for kicks I held a screwdriver across the GPR for about a minute. It seemed to make no change in the way it started so I guess I have to settle for this being a 15W40 issue. I guess on my next oil change I'll find out. That likely won't be until next winter.
Replacing your GPs with new motorcraft units is not a bad job if you want to tackle it - could improve your cold starts a bit. I'd suggest changing out the GPR as well if it's original since, to @T-wood 's point, it's dropping considerably more than 0.3V across the contacts when engaged.
But sounds like you have a work around for cold starts where you can plug in, or accelerate through the romps.
The Monster
Link: https://www.ford-trucks.com/forums/1...-best-gpr.html
Check voltage directly on the battery post. If it's more than 12.2 then you have connection issues between them and the GPR. I would also check them individually, with a cable disconnected from one of the batteries.
I feel .2 ohms resistance between positive terminal and load connection (in this case, positive lug on GPR) is acceptable. Anything more and I keep searching.
0.7v drop across the GPR is also bad. Should be the same on both sides when energized.
My rule of thumb for plugging in was anything below freezing plan on 2-4 hours. I used a Christmas light timer (outdoor and 1500w rated).
Below 20 I just plugged it in all night. Now that I have new glow plugs and injectors It will start fine down to 20, but I still try to get it plugged in any colder than that.
Since I left AK I don't see as many nights that cold, though we did have -8 on new years eve.
So I guess I will be looking for new batteries. These ones are 850CCA Duracells I got from Sam's Club.
FTE'r Y2KW57 made the process of choosing an AGM battery easy for us in the thread linked below.
Link: AGM Group 65 Battery Comparison
If you decide to go that route that is. I bought some NorthStar AGM batteries a few years ago and they are still going like they were new. If they last me 6 years I am even money without having to replace them, so maybe a bit in the positive. If they last me more than 6 years than I am in the positive financially and manual labor wise. Also, I am not left stranded on BLM land out in the middle of nowhere either. That is a good thing in my opinion.
I usually get 6-8 years out of them depending upon use. If your charging system is in good shape and you don't let them sit for too long and/or freeze, they will serve you well.
Before or after you replace your batteries check voltage/resistance between all points. These trucks are known for the crossover cable and terminal ends becoming corroded internally and causing charging issues.
Key Off:
Batteries: 12.25V
GPR in: 12.25V
Key On: (Vacuum Pump was also running)
Batteries: 11.40V
GPR in: 11.15V
GPR out: 11.10V
It probably took me about 30 seconds to measure those voltages with the key on and I jumped in and fired it up. It started almost immediately with very little romping. It revved up and down about 2 times and mellowed right out.
Prior to this I was fully cycling the glow plugs 2 to 3 times (like a 10 minute process) and it was still pretty rough to start it. Tomorrow morning I will go out and try to start it after the wait to start light goes out and see how it does.
Thanks for all your help guys!
