Rough Cold Start
Old Jan 30, 2022 | 05:12 AM
  #76
FinnishStroker's Avatar
FinnishStroker
I always say that money ain't wasted in a new set of batteries.
I suspect that my 2,5 year old set of batteries are done.
140ah 900cca CRX brand(Italy)
Old Jan 30, 2022 | 01:19 PM
  #77
BradyT88's Avatar
BradyT88
So I left the charger on the batteries all night. Early this morning I reset the charger just to confirm it would be full and not settled down. Later when it got light outsides I hooked up my fully charged GooLoo. I cycled the glow plugs for 2 full cycles and started cranking on the 3rd.
I think the GooLoo was kicking out of boost mode because the batteries were almost full from the charge so I don't know for sure how much it helped; but it was completely dead when I stopped cranking.
And with that I just ordered some 950 CCA Odysseys from Autozone. Now I need to look for an AGM maintainer like I see Sous is running.
Shower Thought: it looks like the starter relay is the same as the GPR. Do they fail as often as the GPR and should I just replace it while I am at it? Maybe that is contributing to the slower cranking from some of my previous videos.
Old Jan 30, 2022 | 01:24 PM
  #78
Walleye Hunter's Avatar
Walleye Hunter
I can't remember what RPM's are needed for a start but I'm pretty sure that 100 is too low. New batteries should help with that. If they don't, start checking other things like connections and starter.
L-ight
Apr 9, 2018 10:07 AM
Frank250Tank
Jan 10, 2017 10:00 AM
Jager
17
Nov 29, 2010 08:31 PM
tpolley
32
Dec 9, 2009 09:47 PM
crabio
Nov 15, 2006 07:59 AM
