CAC Pipe Install
Old Dec 19, 2021 | 05:04 PM
pittsy717's Avatar
pittsy717
CAC Pipe Install
Hey everybody,
I replaced the ECT sensor on my 2005 F-250 today and took the CAC pipe off it's upper connection to give me a little more room. Now I cannot get that pipe back on. Anybody run into this, any ideas on how to get that back on? Below is a picture of the pipe i'm struggling with.
Old Dec 19, 2021 | 05:26 PM
AK4x4's Avatar
AK4x4
I have done it in a warm garage and with some wiggling and pushing it went together, sorry I am not more helpful. I recommend a metal replacement CAC (plastic likes to crack) found here; FORD OEM 6.0L V8 DRIVER SIDE CAC INTERCOOLER PIPE UPGRADE Kit 6C3Z-6C640-AA (ficmrepair.com). I also would flush the cooling system and get rid of the green stuff. You want a CAT EC-1 spec ELC coolant, I like Rotella Ultra ELC, but anything meeting EC-1 spec will work great. Good Luck, Russ
Old Dec 19, 2021 | 05:39 PM
TooManyToys.'s Avatar
TooManyToys.
There are times it can be troublesome. A little oil on the ID of the tube, and sometimes I use a cotter pin removal tool to help ease it over like changing a tire. Usually you will find the rubber lip not wanting to over the OD.
Old Dec 19, 2021 | 06:12 PM
six_eaux's Avatar
six_eaux
Long screwdriver, pry-bar, or similar. Tip of screwdriver or whatever you're using in the lifting eye and surprisingly little pressure to the elbow and it pops right on.
Old Dec 19, 2021 | 06:23 PM
pittsy717's Avatar
pittsy717
Thanks Russell! I'm curious about the green coolant too. That was actually put in there by a local Ford dealer when they do were doing some other work for me. Shouldn't it be yellow/gold?
Old Dec 20, 2021 | 08:46 AM
Shiloh51933's Avatar
Shiloh51933
I purchased this CAC pipe to replace the cheap plastic pipe that came with my 2007 F350 6.0l DRW. I believe they changed the CAC pipe to plastic in 2005 but this pipe is a perfect fit.
This CAC pipe looks much nicer in my engine bay and probably less chance of braking when removing/installing.
Old Dec 20, 2021 | 09:11 AM
Yahiko's Avatar
Yahiko
Y used a hot air gun and gently warmed the plastic up and it sips right on with a minimum of force.
And the green stuff should be flushed out. If a Dealer did it I would make them to clean up the mess they made with it.
Old Dec 20, 2021 | 04:16 PM
IHateCommieCars's Avatar
IHateCommieCars
Gold is OK, ELC is better and some of it is red.
Old Dec 20, 2021 | 05:22 PM
bismic's Avatar
bismic
I'll disagree. IMO Ford Gold coolant is a large risk. It will gel or drop solids with the slightest amount of abuse.
Google "6.0L oil cooler plugged up" and I doubt that you will find any examples where EC-1 rated ELC coolant was involved.
Old Dec 20, 2021 | 11:13 PM
Yahiko's Avatar
Yahiko
There is one way to turn the gold into green and that is if they put in the additive package.
Old Dec 21, 2021 | 02:12 PM
FiveOJester's Avatar
FiveOJester
I know the new Ford coolant is some type of yellowish green. My truck came with green when I bought it, but it was more of a bright "neon" than the traditional green so I wondering if it was this new stuff. It's gone now!
To the OP, upgrade to the metal CAC tube. You can get the whole kit for not much money (~$100) and not have to worry about the plastic tube cracking at the bellows (down by the air filter):
https://www.riffraffdiesel.com/drive...ube-kit-03-07/
Old Mar 30, 2024 | 12:37 AM
Chuck322's Avatar
Chuck322
1st Gear
use a hair dryer or heat gun on low to heat slightly
goes right on
im cold weather you will not get these on without warming up
FordActual
Modular V10 (6.8l)
Aug 22, 2018 08:59 AM
lght1
Dec 12, 2013 10:01 PM
redneckfarmers
Exhaust Systems
18
May 13, 2008 10:04 AM
ghunt
General Automotive Discussion
Jan 15, 2008 09:20 AM
TRIMMAN98
May 7, 2002 11:00 AM
