General Automotive Discussion
Pipe cutters
Old Jan 14, 2008 | 12:03 PM
ghunt's Avatar
ghunt
Pipe cutters
I'm looking for a pipe cutter that can cut 3 1/2" and 4" exhaust pipe, is fairly easy to use, and not overly expensive.
I can't find any of the standard exhaust pipe cutters that go over 3 1/4". Most pipe cutters that do accept 3 1/2" or 4" pipe are made for cutting plumbing pipe, and tend to be bulky and expensive.
It's a lot easier to cut pipe with a pipe cutter than a hacksaw. Any of you people know of a pipe cutter out there that doesn't cost a small fortune and will actually cut these sizes?
Old Jan 14, 2008 | 02:59 PM
Bruker's Avatar
Bruker
How about a cut-off saw?
Old Jan 14, 2008 | 03:19 PM
ghunt's Avatar
ghunt
As in the electric kind?
Probably way more than I want to spend.
Old Jan 14, 2008 | 03:40 PM
350steve's Avatar
350steve
How about a sawall..
Old Jan 14, 2008 | 03:52 PM
Bruker's Avatar
Bruker
This one ? http://www.harborfreight.com/cpi/cta...emnumber=44829
Old Jan 14, 2008 | 10:06 PM
ghunt's Avatar
ghunt
Yeah it's real easy to make a straight cut with a sawzall.
Man, one of those would be handy, but seems like overkill to cut a couple pieces of exhaust pipe.
Old Jan 15, 2008 | 07:49 AM
rebocardo's Avatar
rebocardo
The problem with a cut off wheel that size is the heat will damage the thin pipe, badly.
If you are custom making exhaust, then a bandsaw is the thing.
But, just for a few pieces, it is hard to beat a sawzall and you can cut a straight line easy if you clamp the piece in a vise. Just use a short 6" blade and "almost" butt it against the piece. With a 1" stroke, this is enough blade. Where you get crazy angles is using a 12" blade that swings all over the place in narrow material.
Old Jan 15, 2008 | 08:03 AM
51dueller's Avatar
51dueller
You need a chain pipe cutter. You can do 1.5" to 6" pipe.
Old Jan 15, 2008 | 09:20 AM
ghunt's Avatar
ghunt
I've seen some of those on ebay, but they seem to be pretty pricey...
Have my eye on one on there at the moment that says it does 2-4" pipe, so we'll see.
DieselCamper
31
Nov 8, 2016 08:00 PM
GaryKip
Oct 31, 2016 11:34 AM
Fordman96
Michigan Chapter
28
Oct 3, 2016 09:13 PM
JRS2
Apr 17, 2016 08:05 PM
lowtrkn2k
15
Jan 21, 2011 09:12 PM
