Oil Change Mess
Old Dec 9, 2021 | 10:30 AM
jfmaz's Avatar
jfmaz
Oil Change Mess
Hi, I realized at the first oil change almost 40 years ago that I needed to do something to limit the mess created by draining the sump directly onto the cross-member of my 360 (now 390) based F100.
Just wondering what others have come up with to avoid the mess in the last 40 years.
Old Dec 9, 2021 | 12:27 PM
RichS2659's Avatar
RichS2659
There is a drain valve and hose made by Fumoto. I think it came out in the 80's. It is listed on Amazon. There are others out there so google for it.
Old Dec 9, 2021 | 11:28 PM
Pcmdub's Avatar
Pcmdub
Tried that before but the Fumoto valve will not thread onto the pan because it hits the crossmember.
Best answer is some aluminum foil covering the crossmember, and then shape it into a spout.
Old Dec 9, 2021 | 11:45 PM
85e150's Avatar
85e150
Jack the engine up to get clearance. Swerving suggestion.
Old Dec 9, 2021 | 11:54 PM
RedTaurus94's Avatar
RedTaurus94
Fumoto makes several different configurations, I think. Surely one of them will work?
Old Dec 10, 2021 | 12:14 AM
Pcmdub's Avatar
Pcmdub
I have Fumoto valves in my other 4 cars and really like draining into a bottle with zero mess. Tried several styles on the truck and no go. Either they won’t thread because of clearance, or the nub/lever lines up the wrong way. Can’t use their extension, and cannot find an alternative that fits. It would need to be a 35deg angle that threads perfectly, (unicorn). Next time I pull the engine, that oil pan is getting a relocated drain.
Old Dec 10, 2021 | 02:09 AM
Christmas's Avatar
Christmas
X2 on relocate the drain plug.
Old Dec 10, 2021 | 06:58 AM
Dans72's Avatar
Dans72
X3 on relocate the drain plug! I moved mine to the back of the pan, while I had the engine apart. It works much better.
Old Dec 10, 2021 | 09:31 AM
jfmaz's Avatar
jfmaz
Wish I would have thought about that when I did my engine.
I have fashioned a trough (so to speak) out of a 2-1/2" metal stud track with 1-1/2" high legs, a little forming and it has worked great for me for years.
Still wish I would have thought about relocating the drain plug, next time I guess.
Old Dec 10, 2021 | 02:55 PM
1browski's Avatar
1browski
Never thought about changing drain location. I have used all kinds of rudimentary objects to direct the oil flow from the cross member. Cut up water bottles, milk jugs, and paper. Whatever it takes.
Old Dec 10, 2021 | 08:21 PM
FSCboss's Avatar
FSCboss
change your oil pan to a 390 thunderbird or galaxie pan. they are rear drain plug. did mine when i rebuilt the 390. i used the thunderbird four barrel intake also. there is a 390 galaxie oil pan on ebay.
tracyclifton
6.7L Power Stroke Diesel
39
Jun 10, 2016 01:57 PM
SuperBeaner
Aug 5, 2009 02:06 PM
TinyOne
Apr 18, 2006 05:40 PM
Gearhead Jo
Oil & Lubrication
37
Oct 27, 2004 01:12 PM
75explorerxlt
Oct 3, 2002 11:47 PM
