Oil Change Issue
Old Aug 4, 2009 | 01:04 PM
SuperBeaner's Avatar
SuperBeaner
Oil Change Issue
Ok, i realize that this makes me sound like a freaking idiot, but how do i change my own oil when the drain plug for my oil pan is directly over my front crossmember?
Old Aug 4, 2009 | 01:46 PM
jfmaz's Avatar
jfmaz
Makes a mess. I made a small chute out of a 1 1/2" metal stud track for the oil to run in past the cross member into the drain pan. Also when you take off the oil filter (390 fe) it drips all over the place, as it is mounted horizontally. Never could figure out why they didn't mount it vertically. Then you could:
1) change it without the mess
2) partially fill it when changing to make the oil pressure come up faster
3) not need a filter with an anti-drain feature. (Started checking for that after I did my first oil change and the oil pressure took a long time (seconds) to come up every time I started it after sitting overnight.)
Old Aug 4, 2009 | 01:52 PM
SuperBeaner
Thanks man. thats kinda what i figured i was gonna have to do.
Old Aug 4, 2009 | 03:41 PM
70_RangerXLT's Avatar
70_RangerXLT
Those were a couple of Ford's "Better Ideas" back in the day...
Just resign yourself to the fact that there is going to be some mess, and do your best to figure out a way to minimize it.
Old Aug 4, 2009 | 04:37 PM
68horses's Avatar
68horses
I could be mistaken, but I believe there is an oil filter relocation kit for FE engines that orients the oil filter vertically instead of horizontally. Not sure if it's a Ford part or aftermarket. I'm also not sure if there is clearance for it's use on a bumpside. I would love to hear from anyone else who knows what the real deal is. I hate the mess!!
Thanks,
Gene
Old Aug 4, 2009 | 10:23 PM
SuperBeaner
Ive seen those kits too....i think JEGS has them?
Old Aug 4, 2009 | 11:18 PM
krumpelsaurusrex's Avatar
krumpelsaurusrex
I was told just to let it drain all over the place, then my crossmember would never rust!
I used a pizza box folded in half to create a path into my drain pan. Not to hard once you figure it out.
Old Aug 5, 2009 | 11:42 AM
TigerDan's Avatar
TigerDan
Thanks,
Gene
Certain Fords (early Econoline vans, I believe, as well as 2.8/2.9 V6 Rangers) had this adapter. It's also available aftermarket as a Ford Racing part, M-6880-A50, right angle oil filter adapter:
Of course, you can swivel it to orient the filter however you like.
These tend to be a bit on the pricey side, about 72 bucks from Jegs and Summit racing. My '89 Ranger 2.9 V6 came with one stock and those are easy to find in the wrecking yards, so if you really want one, that's where I'd source it from.
Old Aug 5, 2009 | 12:16 PM
Madathlon's Avatar
Madathlon
You can also use a after market kit and relocate on the firewall or fender walls. I do this myself and have the Oil cooler added and a marine expander oil tank, holds 1 gal of extra oil and really helps increasing the oils life.
Old Aug 5, 2009 | 01:32 PM
51MHF5's Avatar
51MHF5
There are also kits out now where you can suck the oil out through the dipstick. http://www.nextag.com/oil-dipstick-tube/compare-html Pretty cheap and you can use them on any vehicle.
Rab
Old Aug 5, 2009 | 02:06 PM
eddiechiles's Avatar
eddiechiles
FE engines in cars had the vertical mounted oil filter if I remember correctly. Not sure if there is a clearance issue in the pickups. Look for one at the salvage yard out of a FE equipped car???
sunuvabug
32
Jul 8, 2020 09:24 PM
Harley Hill
Nov 11, 2016 11:25 AM
littleapple
Aug 13, 2016 09:34 PM
Canadiancowboy
6.2L V8
Jul 4, 2016 01:08 PM
CollinsCD
Aug 19, 2015 09:17 AM
